True-No-Turbo wrote:CAMB01 wrote:Thanks![]()
Anybody got any of those parts?
PM EvilSi, he had a HT18/T3 complete for sale.... I nealy bought it but another deal came up, He may still have it??
TNT
Drifter4ag wrote:ive got one HT18 for sale ... askling for $200 for it
mister2 wrote:
Don't use a bloody adjustable fuel pressure regulator.
Nick
crnkin wrote:hes sorta refering to what you want for big numbers, is a smallish exhaust housing, ie quick to spool on small capacity engine, a bigish shaft and wheel combo, ie flow big air, and a big comp cover, for big air flow. t3/ht18 is mint, has put out 350hp atw on a few cars on 8.0:1 at 24psi, go for it, do it
:madaz: wrote:crnkin wrote:hes sorta refering to what you want for big numbers, is a smallish exhaust housing, ie quick to spool on small capacity engine, a bigish shaft and wheel combo, ie flow big air, and a big comp cover, for big air flow. t3/ht18 is mint, has put out 350hp atw on a few cars on 8.0:1 at 24psi, go for it, do it
this is my view on a smallish turbine and big compressor wheel and shaft;
when a small exhaust wheel is mated to a big compressor wheel, you'll start having problems with exhaust manifold back-pressure, and therefore earlier onset of detonation, which will require you to take more ignition out of it and therefore power is lossed! further,If not ported, and running big boost with the smaller turbine, exhaust gasses are accelled at greater than the speed of sound, which will also cause backpressure issues.
porting will aid this and also a custom manifold which you'll no doubt have. otherwise id stay with a slightly larger turbine wheel, albeit it being 1.6 l.
Users browsing this forum: Bing [Bot] and 17 guests
