4AGZE ECU help
4AGZE ECU help
Postby Caveman » Fri Dec 30, 2005 9:36 pm
Is there anyone in the auckland area that can help me out with my ae101 gze ecu.
Will provide beer to test my ECU on someones car. No danger to your car plus help out a fellow TS'er 8)
Can do it all my self, just need to know someone with a working 4agze - ae101 :D
Thanks
Caveman
Postby KinLoud » Sat Dec 31, 2005 6:35 am
What is the problem with your car?
I had a AE101 GTZ. Computer started to fail:
- check engine light would not light up with ignition on but engine not running.
- check engine light would light up sometimes after starting engine and would remain on for that trip
Then the computer failed
- very poor idle
- engine only went ok when you had some boost happening!
- very tricky to drive due to engine surging on part throttle
- when I tried to get a fault code by shorting the connector the check engine light just stayed on and didn't flash at all
Replaced the computer - everything fixed!
Nuty Mikes flatmate bought my old GTZ, so my old car is in auckland. PM Nutty Mike.
Hope this helps
Ken
Ham
021 408 863
Postby Caveman » Sat Dec 31, 2005 10:53 am
The ECU appears to be working fine. All dash check lights, injectors working but no spark. It throws code 14 which is the Ignition. I've replaced the coils, ignitor, check all the wires including leads but none of this has fixed it :cry:
It did work for about 5 grand seconds 8) Was running off three cylinders because one of the injector plugs was too short.
I turned it off, extended the injector wire, plugged in the air temp sensor and now it won't start, no spark :? I didnt earth the coils properly :oops: so I _think_ a back voltage may have killed something, maybe the ECU.
Do the ae101 DLI coils need to be grounded?
Caveman
Postby rallyrulz » Thu Mar 16, 2006 10:16 am
Hi Ken,
Bad news! I believe the ECU has just shat it self again! The car isnt ideling right now when its warm, the engine light is stuck on, and it stalls sometimes, and it wont let me get the diagnostic codes, i tried to bridge it last night and it just flashed constantly which means normal operation, did it again this morning when I caught it not ideling right and now the lights stuck on. I think this post clears my mind up as im getting pretty stressed finding what the problem might be.
However, what better excuse than to upgrade to a link I reckon, I will check the prices and maybe take it to an auto electrician. You dont think there could be a short or sensor failed do you?
rallyrulz
Postby THA SHZ » Thu Mar 16, 2006 7:02 pm
silly question dylan , but did u pull the terminals off the battery afterwards and then try and read the codes again ?
THA SHZ
Postby Caveman » Thu Mar 16, 2006 9:43 pm
THA SHZ wrote:silly question dylan , but did u pull the terminals off the battery afterwards and then try and read the codes again ?
Yea this thread is old, it was a blow capacitor, the one between the live black-orange wire and the STA ecu wire. Problem fixed 8)
Caveman
