Fueling 4age in KE70
Postby Hachiroku » Tue Mar 21, 2006 10:52 pm
I'm putting a 4age in my ke70 and staying with injection so I obviously need to upgrade the fuel system. What's the best way of doing this? This is what I was thinking:
-Retain standard tank and pickup with extra line into tank for return from surge tank
-Mount a surge tank in the boot supplied generic low pressure electric pump
-Have a 3/8" pipe made up identical to standard fuel line for main line from surge tank to fuel rail
-Use generic high pressure electric pump to supply fuel rail
-Use standard fuel line as efi return to surge tank
Suggestions from others who have done similar conversions would be great.
Hachiroku
Postby Jebus » Tue Mar 21, 2006 10:55 pm
Thats an ideal setup, same as mine, but you forgot about the fuel filter, Nissan Primera is pretty compact and is a good shape.
Theres easier/cheaper ways, but thats a more bling way.
Jebus
Postby Hachiroku » Tue Mar 21, 2006 11:00 pm
Easier/cheaper meaning TE71 EFI tank? What would give a better result in the end?
Hachiroku
Postby Jebus » Tue Mar 21, 2006 11:06 pm
Yeh thats cheaper an easier, A well set up surge tank setup will be better than a factory tank with baffles. Depends if its necessary though, whats the car gunna be used for?
Jebus
Postby Hachiroku » Tue Mar 21, 2006 11:10 pm
Mainly just a daily driver with the odd day at the track. What would you pay for a TE71 tank and lines? I work at a parts shop so I can get pumps, fuel hose, filter etc for cheap.
Hachiroku
Postby Jebus » Tue Mar 21, 2006 11:34 pm
Hachiroku wrote:What would you pay for a TE71 tank and lines?
I wouldnt pay a cent, because thats the last thing i need :P
Jebus
Re: Fueling 4age in KE70
Postby l1ttle_d3vil » Wed Mar 22, 2006 10:20 am
im not sure how similar ke35s are to ke70s but with my 35 there was a bolt in the bottom of the fuel tank (for drainage I presume) so I took that out and put a fitting in there to run the fuel hose to. that saved drilling any extra holes and fittings etc into my fuel tank; and still allowed me to have the breather line etc.
i haven't worried about a surge tank or anything though and never had any problems - except for the time I forgot to fill up and it was almost below E and was cornering hard! :oops:
so I just left all the original lines exactly as they were and ran a new 3/8 line from the bottom of my fuel tank to a fuel pump then to the fuel rail then to the return line (which was the feeder line for the original engine)
Postby wde_bdy » Wed Mar 22, 2006 11:18 am
Won't work on a KE70, tank is under the floor rather than behind the seat. I assumes its a sedan, if its a wagon my setup may be suitable.
Callum
wde_bdy
Postby THA SHZ » Fri Mar 24, 2006 10:24 pm
u will actually find that it has an extra pipe coming out of the tank ready to use for a return line if its a sedan , and wot i did on mine , the cheap ways was using another line and plumbing it in , and used a mitsi starion out of tank pump and peugeot fuel filter 8)
this wrked a treat and didnt cost me buggar all .
remember the ke70 floor plan is identical to the ae86 and u will quite often find tht alot of things are there ready for a conversion , includes holes to mount a different gearbox etc 8)
THA SHZ
Postby Hachiroku » Fri Mar 24, 2006 10:31 pm
Yep it's a sedan. I should be able to pinch a similar pump from a rwd turbo Eterna.
Is it not necessary to keep the breather pipe? Can you just run the return back in there?
Will a ke70 fuel line be big enough for the main efi line or will I need to have one made? ie run 1 for supply and a 2nd for return (cheap cheap :D )
Hachiroku
Postby THA SHZ » Fri Mar 24, 2006 10:44 pm
Hachiroku wrote:Yep it's a sedan. I should be able to pinch a similar pump from a rwd turbo Eterna.
yeah i just ran it back to the breather , esy to make another , and the fuel line should be big enuf , but if u want bigger u could always use garden hose , cheap , cheap :lol:
and yeah i was usin a turbo starion pump , so turbo eterna same sh*t different banana !
THA SHZ
Postby CozmoNz » Sat Mar 25, 2006 7:02 am
HQHAHAHAHAHQQHQHQ U IORUEL~!
Rayne For President!
CozmoNz
