RomanV wrote:Not true, a guy on MR2OC has a '5sge' setup, and is running the standard gen 3 3sge ECU + loom.
However I think he needed to have custom pistons made.
(Or that may have just been to get the 11:1 compression that he wanted)
Adamal wrote:Also, the 3SGE is a MAP motor up until the BEAMS engine, which was then AFM.
AE101stylez wrote:just cos gave it to u it dont mean its urs. ur at uni aye cos i saw it all blak hori in da carpark. more on topic how high revs could the SFE internals handle
strx7 wrote:the air flow meter will register more air going past and compensate accordingly, well at least it should do. We've put a few 2.5 litre V6 shortblocks into Escudo's which usually have 2L in them and their mixtures are fine, the ecu compensates for the extra airflow, i cant see what a toyota efi system shouldn't do the same
