Rattling nose
Rattling nose
Postby xtreme.drifting » Sat Mar 25, 2006 9:38 am
hey,
i've got a rattling noise on acceleration which I think is pinking. Its a 4age an I use 95octane. Would an engine tune fix it?
xtreme.drifting
Postby Zyros » Sat Mar 25, 2006 12:10 pm
Im not much of a technical man.. but it wouldnt be the tappets would it?
Zyros
Postby fx gt » Sat Mar 25, 2006 1:16 pm
sounds like a snake
fx gt
Postby CozmoNz » Sat Mar 25, 2006 3:54 pm
is it a 20v? they just rattle..... lol, its what they do
Rayne For President!
CozmoNz
Postby Caveman » Sat Mar 25, 2006 4:18 pm
Zyros wrote:Im not much of a technical man.. but it wouldnt be the tappets would it?
sounds like a snake
:roll:
xtreme.drifting: What model 4age is it? 20V, 16V, bluetop, redtop, etc.
If you think its detonating you may want to check your base timing, should be set to 10 degrees with te1 and e1 bridged. If your going to use 10 degrees you should really run 98 octane, as in japan they are designed to run on 100 octane. This doesn't include the early big port which have low static compression and should be fine on 95.
4AGES dont have tappets. They use shim under bucket or over bucket depending on what year 4age. You can reset the clearences for your shims which may help quite it down a little.
Could be worn bearings, piston slap.
You may also want to check your fuel pressure and injectors to make sure it isn't running lean, or if you can just get an A/F check 8)
Also do a compression test to check if your bores or rings are excessively worn.
Caveman
