I've still got my original pump on there at the moment. That's why i say rip it off. I'm going to build a little plate and tubing setup that simulates what I'll be taking off. I guess you could just "blank" over where the water pump bolts onto. I haven't investigated fully yet.
I'm running the 80L/min. I'm pretty sure it's heaps big enough. Although the 110 could be a fun experiment if you had something with special requirements.
Also. If you're thinking of a controller I'd wait around to for the new 110 version as it's going to have lots and lots of goood features.
Here's some of the things they planned to incorporate.
Built in cooling timer (think turbo timer), will cool to either set temp or set time.
Digital readout which can show either set point temp, or current temp.
Secondary output relay to trigger another device at a set temp.
One LED to show when the pump is running, and one to show when the relay is active...
I don't know how many of these are going to make it into the final product. But even just a couple will make it a much more useful item.
Alternatively. I'll buy a new controller and sell you my old EWP80 version controller.
