Blow through AFM *now with dyno sheets, 14.4kb users beware*
Postby slighty_sykotic » Tue Mar 28, 2006 12:07 am
yeah, gsr turbo.
evil_si manifold.
--Sykotic
slighty_sykotic
Postby evil_si » Tue Mar 28, 2006 11:46 am
hmm 153hp??,
with a ht18-t3, ae101 ze, with compression at 105psi on each cylinder :roll: i made 181 atw on 11psi
evil_si
Postby slighty_sykotic » Tue Mar 28, 2006 11:52 am
hmm, maybe the dyno was compeltly munted? Dunno, ill take someone in PN for a drive next meet, cause it feels like its got a shit load of power.
Does the gear ratio affect the power readout? Cause I saw he took all of 3 secs to set that part up.
--Sykotic
slighty_sykotic
Postby tsenior » Thu Apr 06, 2006 10:07 pm
lol this post is so funny
YOU HAVE ALL BEEN SMOKING
tsenior
Postby slighty_sykotic » Thu Apr 06, 2006 10:34 pm
?? wtf?
Are you stupid? F uck off boy.
--Sykotic
slighty_sykotic
Postby matt dunn » Thu Apr 06, 2006 11:57 pm
fivebob wrote:How can something that relies on force to swing a flap open be a volumetric device? Take it to the extremes , if the flow is at near total vacuum what happens to the deflection? if you use a very dense liquid what happens to the deflection?
The fact that it works when used under pressure should tell you it's a mass flow device, otherwise it would make the engine way too lean if it only measured volume :?
I still believe they are a air flow only device, not an air mass device as they have no provision for air density.
If they are post turbo, they still have pressure on both sides of the flap,
and the dampening chamber is not sealed so there will be pressure in there as well, and it will only be measuing air volume.
the reason they still work under pressure is because if there is 12psi in there, the engine will have 12psi in the inlet and so will flow more air than at atmospheric pressure.
The ECU may calculate mass by volume and temperature though.
A Hot wire air Mass meter use's current required to keep the wire at a set temperature as it signal, so is affected by volume and density.
Matt
Postby crnkin » Fri Apr 07, 2006 12:27 am
thats real good power, i mean, check out on garage dori, theres a dyno graph of someones, who ran the same setup on bluetop, but with a link ecu, at 11.7psi, running 115kw atw, so 111kw, on a small turbo, on stock ecu, on lower comp, is good, id be stoked with that, its exactly what you would have expected, and thats a good 200hp at the crank, MEAN!
deaf_homo "currrently yes"
crnkin
Postby IH8TEC » Fri Apr 07, 2006 3:38 pm
considering on mine, without external or extra injector, low comp, quite a small t3, std computer. i got 125kw atw on 10psi. running at 10.5:1 a/f, if i made it a bit leaner, i think maybe i could get just over 130.
just as a comparison.
Postby Ebola_One » Fri Apr 07, 2006 3:58 pm
Are you guys forgetting that the dyno topped out at 6krpm? if it's a levin/trueno like in his avatar, and it's on a silver/blacktop (or even a GZE?) there's still more left in it.
GZE's redline at 7krpm? and 20v's red at ~8krpm?
slighty_sykotic wrote:Only revved to 6grand cause of newish engine
There's something to be said for painted on eyes. :roll:
Dirty DA Duz 14.4's, 48's (Taupo) & 1:25's (Manfield)
Ebola_One
TS Wannabe
Sykotic
Postby tsenior » Tue May 30, 2006 9:23 pm
hmm, Do you have a problem? must of got your lunch taken off you at school or something.. grow up! tired of tough talking people on boards.
tsenior
Postby slighty_sykotic » Tue May 30, 2006 9:32 pm
Dude. this post is months old... why dig it up to cause shit?
slighty_sykotic
Postby slighty_sykotic » Tue May 30, 2006 9:33 pm
And futher more, ur post deserved my response. It had no $&#$% point?
--Sykotic
slighty_sykotic
Postby tsenior » Thu Jun 01, 2006 10:28 pm
it was a follow on from page 1, I thought it was a quite a funny little discussion with all the spinny answers, read page one again and hopefully it will make sense, was just trying to get in on the all have been smoking thing.. no real biggy was it. oh i havent been on here in months and the latest response i got is your one, nice.
tsenior
Postby Bling » Fri Jun 02, 2006 1:31 am
tsenior wrote:lol this post is so funny
at the end of the day, when you post useless spam like that, be ready for critisim mate.
any updates on the power figure? or did i miss an updated thread slighty_sykotic?
Postby tsenior » Fri Jun 02, 2006 7:47 am
what ever who cares
tsenior
