fivebob wrote:How can something that relies on force to swing a flap open be a volumetric device? Take it to the extremes , if the flow is at near total vacuum what happens to the deflection? if you use a very dense liquid what happens to the deflection?
The fact that it works when used under pressure should tell you it's a mass flow device, otherwise it would make the engine way too lean if it only measured volume
slighty_sykotic wrote:Only revved to 6grand cause of newish engine
tsenior wrote:lol this post is so funny
YOU HAVE ALL BEEN SMOKING
Users browsing this forum: Bing [Bot] and 18 guests
