How does the automatic select the correct mode (park neutral drive etc) and how does it change up and down in the tiptronic mode?
The reason I ask is that at the moment the tiptronic pushes forward to change up a gear and pulls back to change down, this is just wrong!! If it uses electrical switching to determine the changing then I should be able to switch a couple of wires or the switches to convert it to the other way around.
I am assuming that it is electric as it changes down automaticaly when you come to a halt, the previous Caldina's had shift buttons on the steering wheel and it won't let you shift into 4th until it is warm.
But then as they say assumption is the mother of all toyspeed posts
Info
Discussion
Comments
Posts telling me to search first even though I have.
Thanks
Chris
