4age ECU performance chips
Postby KinLoud » Mon Apr 03, 2006 11:46 am
Comment - your description of what happens when you plug the "chipped" ecu in sounds like the fuel pump is only working when you turn the key to start the motor.
Try jumping the fuel pump connector in the diagnostic plug (not sure if the rwd 4age loom has one?) so the pump runs when the ignition is on then try starting it???
Ken
Ham
021 408 863
Postby l1ttle_d3vil » Mon Apr 03, 2006 12:45 pm
nah the fuel pump is running all the time. its wired up completely separately to the ECU, so the ecu wouldn't effect when the fuel pump is running and when it is not.
