My F*$%^& steering wheel
Postby TruenoBZG » Wed Apr 05, 2006 7:17 pm
Im trying to get my standard steering wheel OFF of my AE111, but it doesnt want to go.
I have a nice new MOMO wheel and bosskit to put on my steering column.
I took off the horn, screws and centre nut holding the standard wheel on, and also the bottom surround, and got out Mr. Hammer and a peice of wood to knock it off.
After around half an hour, Ive decided that Mr Hammer doesnt work. Ive whacked it hard enough to make the whole steering column shudder - nothing. Not even a budge.
Could someone help me with a tool to get this off - without having to bring in Mr. Hacksaw? :evil:
'96 Trueno BZ-G
TruenoBZG
Postby Truenotch » Wed Apr 05, 2006 7:25 pm
Use your head? While pulling on the wheel "headbut" it to get it free. It means you have pressure at the same time as a shock to get it off.
Truenotch
Postby Dragger_Dan » Wed Apr 05, 2006 7:29 pm
Try a little CRC or WD40
Dragger_Dan
Postby trueno_20v » Wed Apr 05, 2006 7:37 pm
yea spray some 556 on there and then hold the steering wheel on each side and push and pull it from side to side if you know what i mean?? i had the same problem came off pretty easy when i done that :D
ADMIN EDIT: signature too large
trueno_20v
Postby rallymazda » Wed Apr 05, 2006 7:41 pm
push pull method on each side is how they come off
[4AGE8U] << my old number plate
Got me a new altezza, now arrived
1991 corolla wagon- work hack
rallymazda
Postby Dell'Orto » Wed Apr 05, 2006 7:43 pm
Leave the centre nut on the thread two or three turns, and then jump backwards holding the wheel, ought to get it off and you wont smash yourself in the face in the process :D
Postby dotdog » Wed Apr 05, 2006 8:05 pm
Its so much more fun when you smach yourself in the head tho LOL, If all else fails you can buy steering wheel pullers, they work mint!
dotdog
Postby Ae92typeX » Wed Apr 05, 2006 8:14 pm
trueno_20v wrote:yea spray some 556 on there and then hold the steering wheel on each side and push and pull it from side to side if you know what i mean?? i had the same problem came off pretty easy when i done that :D
done so many over the years using that method (usually without the 556) have never been stuck yet.
Hope you wernt hitting the centre with the hammer.
Ae92typeX
Postby gordon77 » Wed Apr 05, 2006 8:21 pm
yeah thats how they come off - tried the sudden pull method, it worked but the next day i had a bruise on my chin so wasnt very happy lol
What is RR?
gordon77
Postby TruenoBZG » Wed Apr 05, 2006 8:34 pm
dotdog wrote:If all else fails you can buy steering wheel pullers, they work mint!
Where could I find one of those???
Tried CRC and pulling it, tried brute force, everything that I can with handtools - absolutely nothing. Im scared I'll break something if I keep it up.
'96 Trueno BZ-G
TruenoBZG
Postby TruenoBZG » Wed Apr 05, 2006 8:37 pm
Yeh I know what you mean, tried it.
'96 Trueno BZ-G
TruenoBZG
Postby trueno_20v » Wed Apr 05, 2006 8:49 pm
try harder, it never fails :wink:
trueno_20v
Postby wtfdvs » Wed Apr 05, 2006 10:23 pm
ask your girlfriend :oops:
wtfdvs
Postby AJz » Wed Apr 05, 2006 11:04 pm
steering wheel pullers can be found at like supercheap and repco, bout 15 bucks or sumthing, does the job, quick and easy
I had vtax :(
AJz
Postby TruenoBZG » Thu Apr 06, 2006 7:08 pm
I tried it again this morning, with CRC again - and it worked!
Why didnt it do this the other two days when I was trying? Maybe its slowly worked its way off....
thanks all :D
'96 Trueno BZ-G
TruenoBZG
