trueno_20v wrote:yea spray some 556 on there and then hold the steering wheel on each side and push and pull it from side to side if you know what i mean?? i had the same problem came off pretty easy when i done that
Ae92typeX wrote:trueno_20v wrote:yea spray some 556 on there and then hold the steering wheel on each side and push and pull it from side to side if you know what i mean?? i had the same problem came off pretty easy when i done that
done so many over the years using that method (usually without the 556) have never been stuck yet.
Hope you wernt hitting the centre with the hammer.
dotdog wrote:If all else fails you can buy steering wheel pullers, they work mint!
TruenoBZG wrote:trueno_20v wrote:yea spray some 556 on there and then hold the steering wheel on each side and push and pull it from side to side if you know what i mean?? i had the same problem came off pretty easy when i done that
Yeh I know what you mean, tried it.
