check engine and oil pressure lights on
Postby vvega » Tue Mar 28, 2006 9:39 pm
barryogen wrote:well, semi good news.
the oil pump sh|t itself and an electrical fault in the oil pressure sensor caused the oil light in my car to not come on...
the good bit is that there is a runX front cut with only 12000kms on it coming from Japan to replace mine(75000km), and they're replacing the oil pump in the "new" engine with a new one from Toyota, as the originals are not "known to have a fault", but all the parts guys that my mechanic spoke to, "sugested" that there "may" be a fault where they disintergrate(see pics below)...
2-3 weeks and my baby will be back.
my oil pump
4ages do the same think if you hold them on the limiter to long
its a engine harmoics issue and as 10k20v says is a increasingly comon issue
there are plenty of 2zz powered cars at wreckers
just no engines :D
and at 6 grand for the motor box/loo,/ecu combo it snot likely people are buying them up for comversions :D
forget about turboing it
youll need a m400 minimum to run it properly
v
vvega
Postby 10k 20v » Tue Mar 28, 2006 10:44 pm
DO NOT ANSWER THAT ON A PUBLIC FORUM.
PM the man the info, don't need anyone reporting back to your mechanical insurance people
surely reving to limiter is still within manu operating conditions for the vehicle.
10k 20v
Postby Mr Revhead » Tue Mar 28, 2006 11:07 pm
yeah especially as the powerband is so narrow in these.
it takes practice to use it with out hitting the limiter and/or dropping below 6000rpm.
6000(ish) is where the cams change lobes.
first time i drove one i hit the limiter a few times :oops:
Postby Jebus » Tue Mar 28, 2006 11:33 pm
Mr Revhead wrote:first time i drove one i hit the limiter a few times :oops:
I like to think of the limiter as an indicator to shift gears 8)
Jebus
Postby matt dunn » Wed Mar 29, 2006 1:06 am
and the block is a rough indication of where the rods should be, :lol:
Just asking as there are a few other engine's that have oil pumps that fail when subjected to the harshness of rev limiters etc etc .
Matt
Postby 10k 20v » Wed Mar 29, 2006 1:11 am
yeh, its not uncommon for a 4age to suffer the same fate.
10k 20v
Postby wde_bdy » Wed Mar 29, 2006 8:23 am
Have you tried telling a mechanical insurance company that? It is always far safe to avoid any potential disputes, even if you are rght. :wink:
wde_bdy
Postby barryogen » Wed Mar 29, 2006 8:41 am
when they offered the 1zz, I said only if it comes with the TRD SC kit :lol: ...
they werent so keen when I said that. :roll:
The mechanic said that the little lumpy round thing in the oil pump appears to be a different sort of material in the new pump, sorry, didn't get pics, will if this one falls apart :? :lol:
barryogen
2ZZ Guru in training
Postby 10k 20v » Wed Mar 29, 2006 7:05 pm
hehe
never had too, i seem to get on really well with the companys i deal with.
pratically on a first name basis with autosure 8O :lol: 8)
10k 20v
Postby barryogen » Wed Apr 05, 2006 6:28 pm
It seems that they found the cause of the oil pump failure...
and this URL seems to describe it.
http://newcelica.org/forums/showthread.php?s=06cf6f247004941cb5c05164fcd84539&threadid=110791&highlight=underdrive+pulleys
apparently when fitting very underdrive pulleys on these engines it shakes the sh|t out of the engine... yay...
so, insurance is only covering it as I haven't changed it, no idea how they prove that(I didn't but how'd they know that?).
barryogen
Postby 10k 20v » Thu Apr 06, 2006 11:55 pm
Did you have an underdrive pulley fitted on your engine?
10k 20v
Postby barryogen » Fri Apr 07, 2006 9:30 am
it's certainly not the original one, and it is smaller, so it was assumed that it is not a factory one, they only figured it out when the replacement came along and it was quite a big difference.
barryogen
