Which V6?
Which V6?
Postby GT4 20 » Sat Apr 08, 2006 11:48 am
Just wondering what 'lightweight' N/A fuel injected V6 is fairly readily available here. Mulling over a project idea which may involve using a V6 in a FWD configuration. Would ideally be compact, reliable, readily tunable and uses an ally block to keep weight down.
Suggestions appreciated. :D
Gary
1999 Subaru Legacy B4 RSK TT
GT4 20
Postby RedMist » Sat Apr 08, 2006 11:53 am
I'm going to have a play with a 6a10. Probably not the best v6 for a street conversion... however for a restricted cc class.... its going to be interesting. The big brother 6a12 is a good alloy engine... still not a good manufacturer though.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby GT4 20 » Sat Apr 08, 2006 11:56 am
Showing my ignorance here :oops:
6a10 and 6a12? Who makes these, capacity and power outputs?
Gary
GT4 20
Postby sergei » Sat Apr 08, 2006 12:10 pm
by the name it sounds like mitsi engines (I guess 1.8 )
Postby Lloyd » Sat Apr 08, 2006 12:11 pm
Would be guessing Mitzi by the naming
EDIT - http://www.engineimports.co.nz/petrol_engines.cfm
MT-6A11 MIT SOHC 1.8 EFI GALANT - USED
$937.00
MT-6A12 MIT SOHC 2.0 EFI GALANT - USED
$1062.00
MT-6A12DOHC MIT DOHC 2.0 EFI GALANT - USED
$1062.00
MT-6A12DOHCTT MIT DOHC 2.0 EFI TWIN TURBO VR4 GALANT - USED
$1250.00
Postby fuel » Sat Apr 08, 2006 12:16 pm
Yes, Mitsubishi.
6A10 is 1600cc - one of the smallest production V6 engines - 140hp and some torque to boot.
6A12 is 2000cc, often used in the E84A twin turbo VR-4 Galant, or in the FTO in MIVEC form pushing 200hp.
6A11 is 1800cc, only comes out in SOHC format - not the best to modify.
LOUD NOISES!!!
fuel
Postby Malcolm » Sat Apr 08, 2006 12:56 pm
if you're looking at Toyota, there's the 1MZ-FE, 3L alloy block, ~200hp. Kinda hard to get and expensive though. There's also the VZ series which are cheap and readily available, but iron block
I too would like to know what some good v6s are around the 3L mark that can make good power, hope we're not both thinking about the same thing :P
Postby GT4 20 » Sat Apr 08, 2006 1:51 pm
All_Fours wrote: hope we're not both thinking about the same thing :P
I can guarantee that we're not :wink:
Gary
GT4 20
Postby Dell'Orto » Sat Apr 08, 2006 1:58 pm
I'm sure BBBrad will let his VG20 go to a good home :lol:
Postby GT4 20 » Sat Apr 08, 2006 2:03 pm
Mmm, Boost wrote:I'm sure BBBrad will let his VG20 go to a good home :lol:
GT4 20 wrote:N/A fuel injected V6
:wink:
GT4 20
Postby Malcolm » Sat Apr 08, 2006 2:12 pm
Gary
haha good :) so tell us what's planned then?
Postby Lanius » Sat Apr 08, 2006 3:25 pm
I'm not sure of the engine model, but my ex's (NZ new) MX6 has a 2.5 litre NA V6, and I was always quite impressed with it. Might be worth looking into :) (The JDM MX6 only has a 2 litre, nowhere near as grunty as the NZ New model). They're fwd too ;)
Lanius
Postby fangsport » Sat Apr 08, 2006 3:51 pm
Lanius wrote:I'm not sure of the engine model, but my ex's (NZ new) MX6 has a 2.5 litre NA V6, and I was always quite impressed with it. Might be worth looking into :) (The JDM MX6 only has a 2 litre, nowhere near as grunty as the NZ New model). They're fwd too ;)
same motor as the NZ new telstar V6, manu facturer starts with 'M', leave it where you find it :wink:
what about using the late Nissan V#30 motor? they are alloy block.
fangsport
Postby TRDWGN » Sat Apr 08, 2006 4:27 pm
There is the NZ spec KL-03 2.5l 165hp and then the JDM KL-ZE 2.5l 190ish hp.... for the record the JDM 2l ain't that much less than the NZ spec 2.5 powerwise :wink:
Back on topic, what about the Mitsi Diamante 3.5l mivec 206kw, or the 3.0l mivec 180kw or the FTO's 150kw 2.0l mivec?
TRDWGN
Postby Dell'Orto » Sat Apr 08, 2006 4:31 pm
:wink:
Sorry, VG20DE :P though i think it was a det
Postby BBBrad » Sun Apr 09, 2006 1:20 am
Just a note, "think" the first mentioned mitzi 6a motors are not alloy. They also have stupid rockers, so maybe not a good choice for a high reving na??? The nissan vq20 and vq30 are alloy, a good looking motor but are a chain drive motor and " do" wear out chains, also quite wide. For compactness the best bet is the ford/mazda 2.0/2.5 v6 from the 626/telstar. They can get some huge numbers from them with alot of work, the downside is they have an open deck block (may not be an issue for na)
My new car...99 mr-s
BBBrad
Postby RedMist » Sun Apr 09, 2006 8:53 am
BBBrad wrote:Just a note, "think" the first mentioned mitzi 6a motors are not alloy. They also have stupid rockers, so maybe not a good choice for a high reving na??? The nissan vq20 and vq30 are alloy, a good looking motor but are a chain drive motor and " do" wear out chains, also quite wide. For compactness the best bet is the ford/mazda 2.0/2.5 v6 from the 626/telstar. They can get some huge numbers from them with alot of work, the downside is they have an open deck block (may not be an issue for na)
All the 6a series are alloy. Well they are according to CAPS and web searches, which still doesnt say much. I could imagine the 6a11 and SOHC 6a12 to have rockers. But I doubt the 6a10 or the DOCH 6a12, 6a13 have. CAPS exploded diagram doesnt show rockers either. I'm yet to recieve my 6a10, but I'll inform you about the rockers by the end of this coming week.
I'm not a great fan of mitsi, however a V6 1600?? WOW!
RedMist
Postby GT4 20 » Sun Apr 09, 2006 8:56 am
Hmmm, some very interesting input. I'm suprised that no one has menttioned any of the Honda motors.
Gary
GT4 20
Postby RedMist » Sun Apr 09, 2006 9:35 am
GT4 20 wrote:Hmmm, some very interesting input. I'm suprised that no one has menttioned any of the Honda motors.
Gary
Arent most of the Honda V6's reverse rotation?
RedMist
Postby BBBrad » Sun Apr 09, 2006 9:37 am
Pretty sure they have a hyd lifter/ rocker setup like the 4g63 system. Could be wrong though?
Talking hondas, I done a head job on a honda north/south fwd v6 the otherday. Think it was a 3.2. Was built good but its massive/very wide.
BBBrad
