Can i run a 2jzge with 20valve quads on a link??
Postby Low_Aa63 » Thu Apr 06, 2006 8:36 pm
Got a 2jzge on the way. it's a replacment engine sorta thing with no ecu and a severly chopped loom and im bored with no project atm so i mayaswell throw i in a Ke70.
So my question is how easy/hard would it be to run 20valve quad throttle's with a link on the thing?
Some questions i have are...
.Is there any differences between the silver and black top quads?
.What is the cheapest link ecu i could use? unless there is a better allternative?
.Also does anyone make or know someone who makes an auto bell into a manual for a W series box?
Any help greatly appreciated!
Ben
The list so far
Te71, Ae82, Ke70x2, Mx73x2, Ga61, Gx61, Ra63, Aa63, Ae70, Ae85, Ke25, Ke30, Ke36, Gz10x2, Hb11, Ta40, Ma45......
Low_Aa63
Postby Malcolm » Thu Apr 06, 2006 9:35 pm
it would work, but why on earth would you run quad throttles on a 6 cylinder? Better off running one big one, or maybe 2 medium siized ones if you're too cheap to buy a biggie
Or were you going to run 1.5 sets of the throttles?
Postby matt dunn » Thu Apr 06, 2006 11:43 pm
We used 1.5 sets of 20V quads on our XR6T focus.
After a week of trying and lots of well know people telling us it would not work,
we gave up and fitted a big single on the front.
Basically because of the physical volume of the engine 4000cc,
it causes too large pressure pulses for the map sensor to get a stable reading.
Matt
Postby Low_Aa63 » Thu Apr 06, 2006 11:46 pm
For some reason i thought you could seperate them??
What would you suggest then??
I have also had the suggestion of supercharging it as someone i know ha a moderatly priced sc14 what would suitable injection be for that application or would i be better to stick with the standard injection?
The list so far
Low_Aa63
Postby deaf_rattle » Fri Apr 07, 2006 7:29 am
eaton m90 would probably work ok, i wouldnt waste my time with an sc14
Postby Low_Aa63 » Fri Apr 07, 2006 8:40 pm
Yeah i was relly thinking that if i went supercharger i will just use an old v8 top mount 80x20cm unit i have.
The list so far
Low_Aa63
Postby RedMist » Sat Apr 08, 2006 8:31 am
Matt
Matt, I gather you were using large overlap cams? I also gather you joined all runners together and used a pot to collect all vacuum? Then took map from the collected point?
You could have used something like the Link TPS and MAP settings which uses TPS only for the first 3 rows then map only for the remaining.
Personally I wouldnt bother going ITB on any engine unless its a spec racer and you need every HP. There are much cheaper solutions that will give you substancially more HP, such as turbo or supercharger.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby matt dunn » Sun Apr 09, 2006 8:26 pm
Yes, collected them into a separate chamber/runner to try and give an overall vacuum signal.
Standard cams.
Not only us, Nizpro in australia and motec themselves told us it wont work,
and they should know.
Nizpro has done over 1 year's development on the XR6T's.
Matt
Postby RedMist » Sun Apr 09, 2006 11:42 pm
Standard cams.
Matt
Matt, I've little experience on big bangers (I'm a screamer man myself). I'm attempting to get my head around why ITB affects MAP signal. Surely it shouldnt matter if its ITB or one TB. Unless you are forced to change your map collection point.
Did your solution also mean going AFM?
RedMist
Postby saft » Sun Apr 09, 2006 11:47 pm
isnt he trying to say that with ITB's the "plenum" volume was too small to get a stable pressure reading?
so a big single throttle with a reasonable plenum volume solved the issue?
offtopic, but isnt plenum an odd word
saft
Postby RomanV » Mon Apr 10, 2006 7:24 am
Perhaps he is meaning that the 20v throttles are too smaller diameter, so the force of the pulses coming through them are much stronger than on a smaller engine, which upsets the signal. :?:
Postby matt dunn » Wed Apr 12, 2006 12:57 am
RedMist wrote: Unless you are forced to change your map collection point.
No we are still map sensed,
but the signal now comes from the main plenuim chamber rather than a collection from each of the runners.
Postby Drifter4ag » Wed Apr 12, 2006 10:37 am
youll be fine ..
it will sound freaking awesome
just use the pulsation dampener from a blacktop 20v and you will have no troubles with standard camshafts
Garage |-" '|
Current Rides
AE86 Notchy (Finally through compliance after 5 years)
Vitz RS :D
Previous,
1x SXE10 Altezza, 2xAE111 Caribs, 3xKP60, 2xke35 SR Coupes, 2xAE85s, 2xAE86 Road Car, 1xAE86 Drift Car 182kw@wheels, 1xJZZ30 Drift Car 360ps
Panspeed Special 450ps Drift Car
JZX91 MARK II CHASER
JZX81 MARK II CHASER..... so many more that i forgot....
Drifter4ag
Postby Low_Aa63 » Fri Apr 14, 2006 4:09 pm
Drifter4ag wrote:youll be fine ..
Are you talking to me??
The list so far
Low_Aa63
Postby fivebob » Fri Apr 14, 2006 6:42 pm
If you're only planning on running four of them then you'd have to put them before the plenum, or plenums depending on how you do it. In that case you wouldn't have the so many issues with the MAP signal flucuating wildly.
If you want to run them as one throttle per cylinder then you'll need some sort of signal damper. Which may not be that effective in giving you a clean signal. Wouldn't be as much of an issue on a NA engine as it would be on a turbo.
Postby Low_Aa63 » Fri Apr 14, 2006 7:13 pm
so how the hell do i do it then??
The list so far
Low_Aa63
Postby Low_Aa63 » Fri Apr 21, 2006 10:43 am
anyone?
The list so far
Low_Aa63
Postby scotts2hot » Sun Apr 23, 2006 11:21 am
Convert to carb and run individual carbs instead?
scotts2hot
Postby Lloyd » Sun Apr 23, 2006 11:31 am
Yeah, go for triple sidedrafts :)
Postby Low_Aa63 » Mon Apr 24, 2006 10:18 pm
scotts2hot wrote:Convert to carb and run individual carbs instead?
That would me more of a cost and harder to tune!!
The list so far
Low_Aa63
