Which V6?
Postby RedMist » Wed Apr 12, 2006 8:46 am
10k 20v wrote:class c is 1601cc and over 2wd
class b is 1301cc to 1600cc 2wd
8)
Cugger. Always got my C's and B's mixed up.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby saft » Wed Apr 12, 2006 9:30 am
fuel wrote: The 3.5L 6G74 Pajero Evo motor is 'rated' at 206kw, but in reality it's much more.
are you sure about that, i remember seeing one at a dyno day in pukekohe.
if i recall correctly it put down less power than our slightly tweaked TD42 patrol
saft
Postby GT4 20 » Wed Apr 12, 2006 10:13 pm
Hmmm. Was seriously considering the Mazda K series motor but acording to some engine dimensions I've found on the net, the motor is going to be too long to fit in the engine bay :( If one of the most compact V6s around won't fit, then I doubt if there is anything else out there from Nissan, Mitsi etc that'll fit. :?
Maybe I should just stick a 3SGE in there :lol:
Gary
1999 Subaru Legacy B4 RSK TT
GT4 20
Postby Dell'Orto » Wed Apr 12, 2006 11:23 pm
Put a rotor in it, will fit easily :D
someone had to say it
Postby GT4 20 » Wed Apr 12, 2006 11:34 pm
FWD 13b in a Rover would certainly be different 8O :D
Gary
GT4 20
Postby Dell'Orto » Wed Apr 12, 2006 11:40 pm
Probably leak less oil too :lol:
Postby GT4 20 » Wed Apr 12, 2006 11:44 pm
Mmm, Boost wrote:Probably leak less oil too :lol:
Rovers don't leak oil. They are simply marking their territory :P
:lol: :lol:
Gary
GT4 20
Postby BBBrad » Thu Apr 13, 2006 12:27 am
How about one of these...
A v8 made from 2 hyabusa motorbike engines...Only got 370hp and revs to 10,000rpm.
My new car...99 mr-s
BBBrad
Postby saft » Thu Apr 13, 2006 2:07 am
a gti-r sr20det....
saft
Postby GT4 20 » Thu Apr 13, 2006 7:49 am
BBBrad wrote:How about one of these...
I want!!!!!!!! :twisted:
Gary
GT4 20
Postby Malcolm » Thu Apr 13, 2006 1:06 pm
you'll need to sell the gt4, the rover and probably your house to pay for that motor :wink:
Postby RedMist » Thu Apr 13, 2006 1:39 pm
Naaa it's a cheapie.
http://www.radicalmotorsport.com/news_f ... /index.php
"On alighting, it's difficult to comprehend that the V8 engine was made, as Abbott succinctly put it, "by a bunch of (immensely talented) guys in a shed in Cambridgeshire. What's more exciting is that, at £16,000 plus VAT, it could power a new open chassis European Sportscar Championship, an update of the classic Group 6 series of the 70's. Once Powertec has built enough to satisfy Radical's overflowing order book!"
RedMist
Postby Malcolm » Thu Apr 13, 2006 1:46 pm
ah less than I thought ($45K NZ). The RST is more like 20K pounds, but then I guess it does make 400hp, not a meagre 370 :D
Postby RedMist » Thu Apr 13, 2006 3:22 pm
Thats for the engine alone. Bolted to a quaife, sat in a chassis and clothed is about 85k (UKP)... second hand.
RedMist
Postby Malcolm » Thu Apr 13, 2006 3:31 pm
nah just use the factory rover 'box, run carbs to save on the $$ of ecu, loom, sensors, tuning etc :D
Postby GT4 20 » Thu Apr 13, 2006 4:10 pm
Already have the Quaife straight cut close ratio gearset and Torsen diff for the box :D
Gary
GT4 20
Postby RedMist » Thu Apr 13, 2006 6:05 pm
GT4 20 wrote:Already have the Quaife straight cut close ratio gearset and Torsen diff for the box :D
Gary
The one for the V8 is not just a set of gears in a standard case... its a 6 speed sequential transaxle with an integral dry sump tank (for engine). Custom developed for that specific engine.
Money money money... always money.. in a ri...
But if you want bang for buck... mid engine it and
1- V8 lotus engine (under 1000miles from new), race twin plate paddle clutch, road friendly.
porsche g50/50 transaxle, linkages, driveshafts. large twin turbos, custom exhaust, air to air intercoolers. 'gems' stand alone engine management (mappable) ready to fit!
will fit 4 cylinder chassis! absolute one off opportunity £7000 firm or engine, alone £3500,
Still its only 450 bhp. Perhaps bigger turbos? the GT1 spec engines were approximately double that using the same long block.
RedMist
