4agte clutch, whats everyone using? (fwd)
Postby ~SlideWays~ » Tue Apr 11, 2006 8:52 pm
Hey,
I'm asking this because I've just forked out for a new lsd gearbox and also a linkplus ecu to get the most out of my setup.
This will be for my fwd 4agte (ex-gze).
- First of all, has anyone found the limits of the std clutch?
- Second of all, what are people upgrading to?
I've got a gze flywheel and pressure plate in my ae86 aswell. I had the pressure plate tested (1200ish pounds) and then modified/tested again with a good increase (over 1800). This setup is using a std friction plate but has had the thin 'wafer' removed, which is sandwiched between the 2 sides (this was to make more room due to pressure plate modification).
This clutch setup has worked well with the rwd 4agze but the fwd turbo setup will be making much more hp/torque so don't know whether this will work again, so im looking into options.
Did that make sense!? :lol:
~SlideWays~
Postby trueno_20v » Tue Apr 11, 2006 9:03 pm
well i put my new clutch in before i knew i was gonna turbo it but im running a exedy sports tuff 4 puck kit.. :D
ADMIN EDIT: signature too large
trueno_20v
Postby RedMist » Tue Apr 11, 2006 9:15 pm
I run a Kennedy 4 puck sprung loaded clutch and a double diaphram custom cover by Clutch Systems CHCH.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby HELBND » Tue Apr 11, 2006 9:29 pm
trueno_20v wrote:well i put my new clutch in before i knew i was gonna turbo it but im running a exedy sports tuff 4 puck kit.. :D
i got one of these on my silvertop, would fully recommend it, it bites quite nicely. however can shudder quite badly in traffic if youre not careful
HELBND
Postby Dell'Orto » Tue Apr 11, 2006 9:32 pm
Powerful FWD's just tend to bake tyres, so a reasonably solid clutch in RWD format ought to be fine in FWD.
Postby slighty_sykotic » Tue Apr 11, 2006 11:36 pm
Same as slighty looney.
--Sykotic
slighty_sykotic
Postby Stu- » Wed Apr 12, 2006 10:48 am
I run a solid centre puk clutch and an uprated pressure plate (1900lbs ish). Its slightly tricky when your stop start driving, appart from that its fine. Handles the power no problem so far. I'd just stick with the ze fly and the setup your running, should handle no problems.
Project Thread
Stu-
Postby FLAWLES » Thu Apr 13, 2006 11:58 am
yip im running the same
mine has lasted two yrs now, only just replaced it
:twisted: man that clutch took a beating :twisted:
the only trouble i had was with reversing up a hill, shuddered heaps then
you would be save with this set up
$400 i think from memory and to reline and skim everything about $200
FLAWLES
Postby evil_si » Thu Apr 13, 2006 5:59 pm
pffft aftermarket.
i used the factory gtz one that my car had, handled a beating while i owned it :lol:
evil_si
Postby THA SHZ » Fri Apr 14, 2006 8:22 am
evil_si wrote:pffft aftermarket.
haha top marks for tht man :lol:
im running a hevy duty stndard clutch cause if ur drivin in auckland traffic , u need to be able to slip it , and it will be more than sufficent .
THA SHZ
Postby Bazda » Fri Apr 14, 2006 11:00 pm
I ran a normal clutch plate and a heavy heavy duty press plate on my last car, that was real nice to drive on the road and was real bity when u changed through the gears.
New car im running a 4 puk with a Heavy duty TRD pres plate, and its not nice to drive in traffic as you dont wana slip the clutch and it shuders heaps.
Postby ~SlideWays~ » Sun Apr 16, 2006 12:11 pm
Cool thanks guys, looks like my old setup might work for this one too.
Bazda: out of interest have you dyno'd your new bling engine yet?
~SlideWays~
Postby Bazda » Sun Apr 16, 2006 12:33 pm
~SlideWays~ wrote:Cool thanks guys, looks like my old setup might work for this one too.
dyno will be this week at shore performance, which isnt good to compare dyno results with others on here as it reads way lower than most. Just using this one cos we know the guy and just want it for tuning.
Postby Stu- » Sun Apr 16, 2006 12:38 pm
Bazda wrote:dyno will be this week at shore performance, which isnt good to compare dyno results with others on here as it reads way lower than most. Just using this one cos we know the guy and just want it for tuning.
He read way higher last time I used him, have they finally sorted out the calibration?
Project Thread
Stu-
Postby bluemaumau » Sun Apr 16, 2006 12:39 pm
make sure you psot it up any way, did you get your 1600 dynod there, if so itll be good to see the difference 8)
Postby Bazda » Sun Apr 16, 2006 12:42 pm
yea few months ago he got a new program and it read sky high!!!! like a 200hp escort at the fly, ran like 180kws LOL.
He got it all sorted now, and yea my old car with the t25g ran 130kws.
