Solex Locks
Solex Locks
Postby ke_25 » Sun Apr 16, 2006 10:08 pm
Can you still run central locking with solex locks? some one itld me you cant, but i dont see why not as it is effectively just chnaging the barrels. cheers
PRESENT: KE35 Sr coupe (4agte project), GTS-T, MX40 Cressida coupe
EX:KE25 SL Coupe, KE30 4 door, KP61 4 door hatch, KE36 2 Door Wagon, AE70 2 Door Sedan, AE101 FXGT
ke_25
Postby Sideros » Sun Apr 16, 2006 10:22 pm
No idea, we sell them at work i'll look tomorrow if nobody else has replied by then...
Sideros
Signwriter
Postby Dell'Orto » Sun Apr 16, 2006 10:27 pm
I cant see why it would affect central locking, as you say, its just replacing the barrels.
Postby RickGT » Sun Apr 16, 2006 11:43 pm
if changing them doesnt effect the lock button on the inside then it shouldnt do anything to central locking
MX73 GLXi Cressida 1JZ-GTE
EP91 Glanza V
RickGT
Postby Jebus » Sun Apr 16, 2006 11:47 pm
Someones pulling your leg, it will work fine.
Jebus
Postby ke_25 » Mon Apr 17, 2006 12:04 am
yer thats what i thought, he said he thought he read it sum where. thnx for help
ke_25
Postby Jebus » Mon Apr 17, 2006 12:05 am
ke_25 wrote:yer thats what i thought, he said he thought he read it sum where. thnx for help
Tell him to lay off the meth.
Jebus
Postby ke_25 » Mon Apr 17, 2006 12:08 pm
will do, was much involved in midfying your r33 strut brace? i want to put one in my 35.
ke_25
Postby Ae92typeX » Mon Apr 17, 2006 12:08 pm
will work fine except when you have the lock on deadlock as far as im aware. If you do go for solex, make sure you install well, as its still not much harder than a normal lock to rip the unit out and open the car.
Ae92typeX
Postby ke_25 » Mon Apr 17, 2006 12:09 pm
oh ok thanks for teh advice, yer i just want it for extra secutiry measures as the old toyota keems seem to be able to share around a litle bit. what do you mean wont work on dead lock?
ke_25
Postby Ae92typeX » Mon Apr 17, 2006 2:56 pm
Im not sure if all the solex models have deadlock capability, or not, but essentially, its when you turn the key all the way one way, take out, and it can only be unlocked with the key- not from the inside, or via central locking servo. It also has a normal lock function which will be ok.
considered just putting an alarm with central locking and diabling the exterior lock latch?, imo, a slightly more secure method.
Ae92typeX
