Which Valves
Which Valves
Postby CAMB01 » Tue Apr 18, 2006 7:24 pm
What would be a suitable option for going to larger valves on my 4AGE cylinder head.
What valves i could use?
Cam
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby Grrrrrrr! » Tue Apr 18, 2006 10:36 pm
If you supplied a bit more information it would help..
At the very least stating which generation 4AGE you are talking about would help, and what sort of budget you have, and are you talking about building a boosted beast? high reving NA screamer?
A boosted motor will have to deal with more heat, but at lower RPM than an NA screamer, so valve weight isn't such a big issue.. but if you want a 5 digit rev limit then valve weight is going to become an issue.
And you realise that you will need to machine the head, possibly get new valve seat inserts & guides made/fitted etc? this could be more expensive than you think.
Contact an engine builder for a rough price for that sort of work might be a good idea.
and if you can provide measurements for the valves you currently have that would help.. valve diameter, stem diameter and length for intake and exhaust valves would make it a lot easier for people to help you.
Grrrrrrr!
Postby Adydas » Tue Apr 18, 2006 10:46 pm
Details, what are they :P
Adydas
Postby Grrrrrrr! » Tue Apr 18, 2006 10:50 pm
those things that are kept up on the shelf next to the hens teeth, C52 gearboxes that dont crunch and spare 4AGZE DLI setups.. just push aside the bag of rockinghorse shit ;)
Grrrrrrr!
Postby CAMB01 » Tue Apr 18, 2006 11:18 pm
Well im a motor machinist so machining isnt a problem.
Its for my 4AGTE im currently building. Running a smallport 4age head.
Will have custom made cams for it so was looking at increasing the amount of air and gas in and out of the engine.
Currently the valves i have a standard ones.
Inlet:
6mm stem diameter
100.5mm stem length
30.5mm head diameter
Exhaust:
6mm stem diameter
100.5mm stem length
25.5mm head diameter
Was looking at using valves from a 3sge but the stems are too long and the keeper grooves arent in the right place.
Any suggestions?
Cam
CAMB01
Postby 4agtepwr » Tue Apr 18, 2006 11:49 pm
Im an automotive machinest as well and coming up to this stage in my build. I looked at aftermarket valves but i think beause of there size you would have to fit new inserts being 2.5mm bigger in the head of the valve.
Im going to look at shortening and machining some 3sge stainless valves but otherwise i can't see many other options.
Current ride: Sweeeeet Hiace. 3L power!!!!
Project: AW11 4agte, 410kw 555hp on 26psi
11.1 @ 125.5mph with more to come, As seen in Aug 2011 Performance Car, haha
viewtopic.php?t=61383
Huge thanks to Phil from NZEFI, Al and Brendan from Caraid and Hamish from Sheifield Cresent Auto
4agtepwr
Postby AE85coupe » Wed Apr 19, 2006 11:39 am
could try 7MGTE valves
supposedly they are the same as TRD big valve kits for 4ages
they are about 2mm to short, but could use thick shims
AE85 Trueno *For sale*
Details of car here
AE85coupe
Postby CAMB01 » Wed Apr 19, 2006 8:47 pm
Was looking at maybe 3SFE valves might work, aparently the keeper grooves are at the same height as 4AGE valves, but the stems are 1.5mm longer, thinking could just grind that off the stem if there is enough metal above the keeper groove. Dont want the springs breaking off the end of the stem cause i took too much off.
Was talking to my cam grinder today about the specs on my cams and he suggested using 3SGE buckets with under the bucket shims.
I was under the impression 3SGE buckets were larger and hav the shims on top?
Can anybody help me with this?
I have used these cams before and had heriffic tappet noise cause of the shims rocking on the buckets from the high lift.
CAMB01
Postby Mr Revhead » Wed Apr 19, 2006 9:37 pm
later 3sges are shim under bucket
but they are too big, need to machine out your head to fit them
Postby CAMB01 » Wed Apr 19, 2006 10:44 pm
hmmmm might have to ring my cam grinder about that, he was saying they went straight in.
I guessed they would be bigger cause the earlier ones are.
What other buckets with the shims underneath would fit into a 4AGE 16v head.
Cam
CAMB01
Postby Mr Revhead » Wed Apr 19, 2006 10:53 pm
1sz engine
cost about $30 each.... one piece bucket and shim
first iv heard of 3sge ones fitting straight in
would be good if the did, but i doubt very much they do
Postby RedMist » Wed Apr 19, 2006 10:53 pm
Apparently the 1sz-fe buckets work wonders.
http://www.club4ag.com/faq%20and%20tech ... uning.html
The trouble is working out your clearances.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby CAMB01 » Wed Apr 19, 2006 11:35 pm
grind the tips of the valves or reface them, cut the seats to set the clearances if using a one piece bucket
Are there any other under bucket shim setups that would work?
I like the idea of having shims as i find it to be alot easier to get the clearances accurate.
CAMB01
Postby Grrrrrrr! » Mon Apr 24, 2006 3:24 am
just stumbled across this page, may be of interest to you
http://www.importperformanceparts.net/i ... oyota.html
Grrrrrrr!
