Pod filter probs?
Pod filter probs?
Postby The Game » Sat Apr 22, 2006 12:29 am
when my car is in idle, the pod filter makes a strange sound like kind of low whistling noise then every so often the tone will change to a different sound and then change back again...understandable? i just wanted to know if it was normal or not.
chur
The Game
Postby sergei » Sat Apr 22, 2006 12:30 am
it is your idle control valve whistling. completely normal.
Postby The Game » Mon Apr 24, 2006 1:05 am
even changing tones?
The Game
Postby Ae92typeX » Mon Apr 24, 2006 8:59 am
will be fine. Probably some other valves switching. Does it run funny/bad at all?
If you had a standard filter, you just would not hear these noises
Ae92typeX
Postby barryogen » Mon Apr 24, 2006 9:56 am
whats your car?
barryogen
2ZZ Guru in training
Postby The Game » Mon Apr 24, 2006 10:20 pm
96 trueno. well its just that it never used to make as much noise, and the whistling while driving is much louder than it used to be.
The Game
Postby sergei » Mon Apr 24, 2006 10:21 pm
check your pod underneath if it has not rubbed through itself on engine mount..
Postby The Game » Tue Apr 25, 2006 8:20 pm
its just that when in idle it makes this noise like pssssshhhshshhshs
and driving the whistling is really loud
The Game
Postby Emperor » Tue Apr 25, 2006 8:22 pm
It hasn't been converted to turbo has it? :lol:
My Skyline does that, not that loud but it wasnt there when I had the stock panel filter
Emperor
Postby The Game » Wed Apr 26, 2006 7:19 pm
lol no way
The Game
Postby Caveman » Wed Apr 26, 2006 8:37 pm
It sounds normal
Want reassurance? Take it to a mechanic
Caveman
Postby Ae92typeX » Wed Apr 26, 2006 8:44 pm
as above, but when did you last clean it? possibly could be a little more gunked up, and if an oil type, dry.
Ae92typeX
Postby ollieboy » Wed Apr 26, 2006 9:48 pm
I once had a starlet that sounded like it had a spooling turbo, it was just normal sounds from the induction that were really loud. Just appeared over time, maybe same thing.
ollieboy
