Need some specific advice on track setup AE101
Postby 4000GT » Tue Apr 25, 2006 7:34 pm
Hey guys,
Firstly hello! Its nice to have a forum dedicated to Toyota in NZ.
I picked up a junker Levin AE101 with a silver top. I have a 6 speed gearbox with LSD going in and some wheels which I will get DOT tyres for. I also have a 3 puck brass button clutch disk going in. Other than that, and a rediculous carbon T spoiler and fibreglass bumper, the car is stock. Its going to be a club car then probably a fully caged race car. Can anyone direct me to upgraded supension and brake parts for the AE101, and give any track experience with them. I have modded cars before, but not a FWD Toyota so the parts from other models and aftermarket suppliers are new to me... I dont have a huge budget, so innovation is appreciated!
TIA
Andrew
Supra MKIV Aerotop (UZA80FTE conversion) STATUS: 3 months to go!
Nitrous is like a hot chick with a STD..... you know you wanna hit it, but you are afraid of the consequences.....
Free online business and reporting tools visit www.e-solver.com
4000GT
Postby bluemaumau » Tue Apr 25, 2006 7:36 pm
hmm ae101 gtzs have two pot front callipers if that helps
straight bolt up jobbie
Postby 4000GT » Tue Apr 25, 2006 7:58 pm
What about the ST205?
4000GT
Postby Caveman » Tue Apr 25, 2006 8:39 pm
First off good choice of car. Corollas are the shit
TRD do a set of rally springs. They retain standard ride height but are stiffer, especially the rear. These can be got from a genuine toyota yard for around $100 per corner. I have only raced on standard and whiteline springs. Standard where far too soft, the body roll made the car hard to control. The whiteline I have are ok, they are too soft at the rear and it feels like the front oversteers to easily. I am upgrading to TRD, heard very good things about them. Im getting the sports springs which is stiffer but also lower.
Next step I would take are adjustable shocks all round. Stiffer shocks will allow you to shift the weight quicker. Im sure other people on here know a lot more about me than suspension tuning so ill wait for there input.
You should have no problem getting the car under 1000kg. The sound detoning stuck to the floor weighs about 15kg. Its tedious and boring to remove but worth it IMO.
Power shouldnt be too much of an issue unless its circuit. If its rally hill climb/auto cross just stick with the basic bolt on exhaust and filter. 2 1/4 is a popular 4age exhaust size. If you need the power it will be an expensive job extracting it (other than the bolt on's). You will need big cams and a new computer to run them, along with all the supporting mods (ignition, bigger fuel supply, head work, etc)
Good luck with it.
Caveman
Postby Bazda » Tue Apr 25, 2006 9:15 pm
bluemaumau wrote:hmm ae101 gtzs have two pot front callipers if that helps
thats not true.
All superstrut ae101s ae111s have the 2 pot calipers & bigger dics, if its not superstrut it just has the singlepot.
And they wont fit onto a non superstrut car unless you made an adapter plate for the caliper.
Postby bluemaumau » Tue Apr 25, 2006 9:23 pm
thats not true.
o true, well you learn somthing everyday, why did they make the superstrut only have double pot????
Postby 4000GT » Tue Apr 25, 2006 9:43 pm
1998 wrote:First off good choice of car. Corollas are the sh*t
Good luck with it.
I actually dont like the car, but at least that way it doesnt matter if I crash or damage it :P
Its a track car, not hill climb etc. At least not at the moment. Do you happen to know a good supplier of TRD springs? Dealers tend to be more expensive in my expereince for the same parts. What adjustable shocks fit in the stock strut? What about camber plate uppliers?
Thanks
Andrew
4000GT
Postby Bazda » Tue Apr 25, 2006 9:45 pm
I have camber plates to fit ur car, soem guy off trademe bought them but i havent heard back from him, wanting $225 for them
Postby bluemaumau » Tue Apr 25, 2006 9:46 pm
superstrut?
Postby Bazda » Tue Apr 25, 2006 10:17 pm
bluemaumau wrote:superstrut?
they will fit any toyota shocks, you just gota lathe up a spacer depending on the diameter of the strut leg.
Postby bluemaumau » Tue Apr 25, 2006 10:20 pm
:lol:
nah you posted just before me, i was asking the poster if his car was superstrut
:lol:
Postby Mr Revhead » Tue Apr 25, 2006 10:22 pm
fit a whiteline rear sway bar, that will make a huge difference
i can supply thise as well as TRD parts.
Postby 4000GT » Tue Apr 25, 2006 10:45 pm
Mr Revhead wrote:fit a whiteline rear sway bar, that will make a huge difference
Can you please PM me a price for the whiteline bar (is it adjustable?), and TRD coilovers (are these camber adjustable models?)
Cheers!
Andrew
4000GT
Postby bluemaumau » Tue Apr 25, 2006 10:46 pm
click revheads link in his sig.
Postby 4000GT » Tue Apr 25, 2006 10:52 pm
Bazda wrote:I have camber plates to fit ur car, soem guy off trademe bought them but i havent heard back from him, wanting $225 for them
Thanks, what brand are they? What degree movement do they have?
Cheers!
4000GT
Postby Caveman » Wed Apr 26, 2006 12:02 am
Email RevHead. He sorts out all the TRD parts for us. Genuine toyota arn't too bad price wise. They are usually pretty good to me supplying cheaper than ripco, supercrap, etc.
Caveman
Postby Bazda » Wed Apr 26, 2006 4:38 pm
Cheers!
no brand name, I use them on my car, they adjust +/- 5 deg
Postby 4000GT » Wed Apr 26, 2006 6:02 pm
Cheers!
Ok, seem to have enough movement, but I am kinda over not buying high quality parts for my cars, especially suspension on a track car.
4000GT
Postby Bazda » Wed Apr 26, 2006 6:39 pm
CircuitLevin wrote:
Cheers!
these are very good quality and well made, I have pulled them apart to inspect them as well, i wouldnt use crap on my car, especailly when its 400hp. I will also be doing some track racing with mine.
They have a proper ball swival mount in them.
also when u put more camber on it puts on more caster at the same time as when u mount them onto the car they are offset slightly.
Postby 4000GT » Wed Apr 26, 2006 7:29 pm
Bazda wrote:
CircuitLevin wrote:
Cheers!
I would get longer ball joints to correct the geometry...
How do you know they are very good quality? What grade hardware was ued? What grade alloy? How were they machined? To what tolerances? What grade bearing? etc?
4000GT
