brake master cylinder ae92
Postby deaf_rattle » Sun Apr 23, 2006 10:11 pm
i have failed my wof because of a suspected leaking brake master cylinder...
the guy said if it wasnt leaking to dry it up and take it back clean.
if it is leaking what is involved with replacing/fixing this?
Postby Rick » Sun Apr 23, 2006 10:35 pm
Its just a matter of replacing th seals, but if the cylinder is corroded then you might have get a new master cylinder, or a non corrroded second hand one.
Postby bluemaumau » Sun Apr 23, 2006 10:41 pm
its like 3 bolts from memory if you need to replace it + all the lines
+ i guess youll need to bleed the system
Postby Nuty|Mike » Sun Apr 23, 2006 11:13 pm
Rick wrote:Its just a matter of replacing th seals, but if the cylinder is corroded then you might have get a new master cylinder, or a non corrroded second hand one.
Ill have a look for a new cylinder at work for you no point in changing seals when a whole new unit aint gonna be much more expensive
05 Mazda Verisa .....for the Family
Nuty|Mike
Postby fangsport » Sun Apr 23, 2006 11:54 pm
what he said, unless it's an oddball (not likely). my old boss used to get me to have wheel cylinders re-kitted all the time, when a brand new cylinder was 3/4 price of the kit, let alone adding labour onto it.
fangsport
Postby fangsport » Sun Apr 23, 2006 11:55 pm
what he said, unless it's an oddball (not likely). my old boss used to get me to have wheel cylinders re-kitted all the time, when a brand new cylinder was 3/4 price of the kit, let alone adding labour onto it. besides, a re-kitted one will never be as good as a new one, especially if the honing dosn't get all the pitting out.
fangsport
Postby gepsk8 » Wed Apr 26, 2006 12:12 am
if the cars got a EFI 4age which im guessing it is, it will take a bit of time to get at, as i wrecked one and it still looked like a mission to get at if the motor etc was in the car.
gepsk8
Postby bluemaumau » Wed Apr 26, 2006 10:01 am
gepsk8 wrote:if the cars got a EFI 4age which im guessing it is, it will take a bit of time to get at, as i wrecked one and it still looked like a mission to get at if the motor etc was in the car.
true ive only done it with no engine, im sure its possible, just may be a pain
