Gear stick Knob
Gear stick Knob
Postby Zyros » Thu Apr 27, 2006 3:12 pm
Okay, this is by far going to be the stupidest thing to ask in a technical forum :lol:
My gear-stick knob is massively high, due to the stick being way to long..
I want to shorten it, but im not sure how to go about this.
If i hack saw it, then i would be cutting off the thread's on the stick which are used to screw on the gearstick knob.
If i glue it or whatever, its impossible to remove if i ever had to eg- Removing the pannel etc.
Any idea's on how to shorten my gear stick, yet be able to still change the gear-stick knobs when needed?
:roll:
Zyros
Postby Alex B » Thu Apr 27, 2006 3:14 pm
If your going rangi styles just put a new thred on whats left of the stick.
Postby Silent Knight » Thu Apr 27, 2006 3:21 pm
Cut/Weld the stick.
Silent Knight
Postby pc » Thu Apr 27, 2006 3:36 pm
Raise your seat :P
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby Caveman » Thu Apr 27, 2006 3:56 pm
pc wrote:Raise your seat :P
Raise the seat in an ae92 and you'll _need_ to cut the roof off.
Easiest way is to cut a section from the middle and weld it back together. You need to chamfer the section before you weld to get a good join
Caveman
Postby crnkin » Thu Apr 27, 2006 4:11 pm
ben, dont forget to tell them its an auto..
just kidding
deaf_homo "currrently yes"
crnkin
Postby bluemaumau » Thu Apr 27, 2006 5:35 pm
just hack or grind it off, most aftermarket knobs need a little plastic condom thingy to screw into anyway 8)
Postby Ae92typeX » Thu Apr 27, 2006 7:16 pm
I find the easiest way is to cut, then drill the top of the new length, tap, insert bolt minus head and presto, done.
but thats being assuming of peoples abilities to drill and tap of corse.
just dont go around saying you have a short shift stick....
Ae92typeX
