Levin BZR - Any issues i should know about?
Postby adamkerrnz » Tue May 02, 2006 10:34 am
Hello,
Im thinking of "moving up" to a 1997 Levin BZR. its got 120,000k's on the clock and for those that dont know, a blacktop 4AGE and 6 speed gearbox
now, are there any ongoing problems that i could possibly have with this car?
any input is appreciated
2003 Toyota Echo 1.3
adamkerrnz
Postby Leon » Tue May 02, 2006 11:20 am
Oil consumption (standard feature)
Super Strut worn out
Crunchy synchro's
That's about all I can think of.
Postby demis » Tue May 02, 2006 10:25 pm
hay not all black tops use oil thank you very much :)
some have problems with hesatating when cold , not sure what causes it, but i would like to know
EX 1984 Corolla FX GT (AE82) 1st gen 4age
EX 1996 Corolla BZ touring (AE101) 5th gen 4age -LSD
EX 1997 Carib Z touring (AE111) some 4afe muck
Ex 2000 Fielder S (ZZE122)- Its BIG RED
2002 Corolla Ts (ZZE122) Mr ~ Ts
demis
Postby ollieboy » Tue May 02, 2006 11:01 pm
They're quite gutless low down in the rev range. :o
ollieboy
Postby NILPSI » Tue May 02, 2006 11:37 pm
demis wrote:hay not all black tops use oil thank you very much :)
I second that i have no oil worries with mine, I also get hesitating when its cold, but it doesnt seem to go away when its warm (its the one thing that i want to fix on my car that i havnt yet been able to find the cause of)
Oh and the synchros and reverse seem to be a normal problem in most toyota gearboxes, all 3 of mine have had issues (2 x 20v's and a *coughcoronacough*)
17 Triton - The "free supplied by work" daily
09 Aurion Sportivo - The Daily
97 Trueno BZ-G - The Garage Queen
97 Supra SZ-R - The never ending project... now with added boost!!
NILPSI
Postby CozmoNz » Wed May 03, 2006 12:26 am
Get the throttle body's Cleaned out...
Rayne For President!
CozmoNz
Postby Leon » Wed May 03, 2006 10:40 am
wasn't specifically aimed at blacktops, but at 4AGE's in general :)
Postby Mr Revhead » Wed May 03, 2006 2:02 pm
yes oil usages is common, but not a real issue
to fix that hesitation check:
leads, cap, plugs
run it on 98 or retard the timing to 8deg for 95 NEVER run 91.
fit oil catch can, one with NO drain or return
Postby Dell'Orto » Wed May 03, 2006 2:03 pm
All of those things have been done.
Postby dotdog » Wed May 03, 2006 5:59 pm
Yea, I 3rd the hestiataion when its cold, but mine comes right after about 2minutes of driving.
The syncros sucks in the 6speed, my 4th gear is on the way out.
Superstrut, mine has 121kms on it and one of the superstrut joints is on the way out
Other than that it has been the most reliable car Ive ever owend, Ive done 20,000kms in mine and they only thing that has died is the thermostat which was a whole $20 from toyota for a new one, oh and I had to get the cat cut out cause it got a bit stinky
dotdog
