Wire connectors
Wire connectors
Postby flat_0ut » Fri May 05, 2006 7:57 pm
What's the best way to connect wires? A the moment i'm using duck tape :oops: and some of those plastic connector things which seem to work but no shops seem to tell them?? What's everyone else using?
flat_0ut
Postby ollieboy » Fri May 05, 2006 9:18 pm
Solder the joint then shrink wrap them or electrical tape.
ollieboy
Postby 2LTR Rona » Fri May 05, 2006 9:39 pm
Or you could try this have used this method a number of times on numerous applications, never fails to give a good solid connection
Much easier as you dont have to worry about having a soildering iron laying around in possibly a cabin etc
2002 Altezza, 1974 KE25
2LTR Rona
Postby flat_0ut » Fri May 05, 2006 9:44 pm
2LTR Rona wrote:Or you could try this have used this method a number of times on numerous applications, never fails to give a good solid connection
yeah, thats what i've been looking for. Can't believe I didn't try dick smith! :roll: Thanks heaps
flat_0ut
