vvt not working?
vvt not working?
Postby deaf_rattle » Fri May 05, 2006 10:00 pm
it has been suggested that the vvt in my corolla is no longer working.
is this an easy fix? or should i not worry about it?
Postby trueno_20v » Fri May 05, 2006 11:34 pm
well dos it feel slower?
ADMIN EDIT: signature too large
trueno_20v
Postby AceSniper » Sat May 06, 2006 4:55 am
put 12v on the solinoid while idling see if it goes lumpy... eliminate the pully an solinoid, then work the way back
AceSniper
Postby deaf_rattle » Sat May 06, 2006 9:50 am
yeah, car feels noticebly slower.
revs right out still but definately slower
doesnt seem to pull as much in the high revs either
Postby FXGTV » Sat May 06, 2006 11:21 am
deaf_rattle wrote:yeah, car feels noticebly slower.
Get v-tax then ;)
1988 r31 TI Skyline.
1982 ra60 Celica (my Aussie Toyota and axle stand warrior).
ex: 1991 Corolla, 1989 fxgt-v, 1985 aw11. 1992 sw20 gt-s. 2002 glxi Lancer wagon (work hack)
next car - another a-dub please!
FXGTV
Postby RedMist » Sat May 06, 2006 11:25 am
VVT is disabled obove 6k. I think you are looking at more of a missfire issue.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby AceSniper » Sat May 06, 2006 2:14 pm
6k? all silvertop ecu's cut it on redline
AceSniper
Postby slighty_sykotic » Sat May 06, 2006 4:39 pm
Its not 6k, and its not redline, i can't quite remember, but I had a VVT light in my 20v, and it goes out around 800ish before redline i think. Def more than 6k though, and it deff isnt redline.
And you test if its working (the accutal pulley), you need to do the 12v test.
--Sykotic
slighty_sykotic
Postby Bling » Sat May 06, 2006 7:24 pm
slighty_sykotic wrote:it goes out around 800ish before redline
i'd agree with that 8)
Postby RedMist » Sat May 06, 2006 7:37 pm
Sorry I never ran a stock ECU. I was attempting to quote an older post of Revheads, however it appears I got the cuttoff incorrect.
RedMist
Postby AceSniper » Sat May 06, 2006 7:50 pm
I know blacktop's turn off b4 redline (before silvertop turns it off I think even) but every ecu iv had in mine has been redline facelift an sard 101 ecu's
a issue were blacktop vvt may not work is a overheating part in the ecu that fries itself, havent seen it but there is a site all about it, havent seen it with silvertop, so if anythings failed Its prolly the pully or solinoid
AceSniper
