Grrrrrrr! wrote:From reading the regulations and what information i have been able to find i've come to the conclusion that the TRS engines are running standard hardware, just blueprinted and drysumped (possibly to prevent oil surge due to the expected cornering forces? or grenading oil pumps ).
Claimed horsepower is approx 200, which is consistent with the gains to be expected from the free flowing exhaust, intake and ECU.
remember that these motors would have been chosen to be reliable and cheap (relatively) for toyota to provide for the series.
Grrrrrrr! wrote:So from that we can see. a b16a runs bigger valves, at higher/similar lift (on the high lobe) than a Formula Atlantic motor, just shorter duration to keep the power down in a useable revrange.. if it wasn't for the vtec system i wonder how driveable they would be down low?
crnkin wrote:makes a superior engine in a disappointing line of cars.
Lanius wrote:You're going to run into detonation trouble with a higher CR than 11:1 on NZ pump gas
I would expect that the ECU will retard the timing on the engine should it sense any knocking, and you'll end up with poorer performance than you would have had with the standard HG
skoty wrote:crnkin wrote:makes a superior engine in a disappointing line of cars.
Yeah fully agree, I mean why does Honda put decent motors like the B16A/B18C into absolute pieces of sh#t. Correct me if I'm wrong but arn't the only production RWD Hondas the S2000 & NSX?
...ahh well I just know I will never buy a Honda till the day I die
everyone knows honda make the best hp/L NA engines,
MetalupYoAss wrote:skoty wrote:crnkin wrote:makes a superior engine in a disappointing line of cars.
well toyota only made bluetop 4ages RWD the rest are all FWD aswell; everyone knows honda make the best hp/L NA engines, your stock b16 will beat your stock 4ag.. end of story
