Speedometer bouncing...
Postby Wolf_Tm250 » Sun Mar 26, 2006 11:28 pm
Hi All !
I have a problem with my speedo
when I use the car, it's always bouncing nervously ...
Please look here:
http://wolf250tm.altervista.org/Video/W ... 200602.WMV
I thought it was a sensor plug problem, but it's ok...
What could it be then ? The sensor itself ?
The digital conversion of the Motec ecu ??
TIA !
Bye...
Wolf_Tm250
Wolf_Tm250
Postby vvega » Mon Mar 27, 2006 8:14 pm
probaby the sender
put out th sendwe and have a lok at the toothed wheel
if its damaged then replace it
v
vvega
Postby Wolf_Tm250 » Mon Mar 27, 2006 8:23 pm
vvega wrote:probaby the sender
v
I knew I had to take it out....
I just wanted to have a confirm...
Thank you vvega! :)
Wolf_Tm250
Wolf_Tm250
Postby Wolf_Tm250 » Tue May 09, 2006 9:16 pm
v
Hello,
I put out the sender, but the toothed wheel wasn't damaged...
I still have to understand why my speedo bounces !!!
Wolf_Tm250
Wolf_Tm250
Postby vvega » Tue May 09, 2006 9:33 pm
it is a electric speedo ???
v
vvega
Postby Jazza » Tue May 09, 2006 10:09 pm
I cant view the vid, but depending how much it bounces your car may have had its speedo wound. As you are decelerating... if it bounces slowly back up slightly, it could be that. Are your Km's certified?
Jazza
Postby Wolf_Tm250 » Tue May 09, 2006 11:11 pm
Vvega,
yes, the speedo is electronic.
I put out the sender, found a toothed wheel, a magnet and a 3 pin plug...
probably the sender is a little electricity generator...
MY car/speedo is 90.000 kms old, and the speedo is bouncing especially when accelerating...
Thank you, bye...
Wolf_Tm250
Wolf_Tm250
Postby Wolf_Tm250 » Tue May 09, 2006 11:21 pm
Jazza wrote:I cant view the vid,
Right click/Save as ?
Wolf_Tm250
Wolf_Tm250
Postby sergei » Tue May 09, 2006 11:22 pm
This problem can be becuase of the bad ground either in the engine bay area or speedo area, check if all screws behind speedo are tight and not corroded.
Or dry soldering inside of the speedo (arround "stepper" motor area)..
Postby Wolf_Tm250 » Wed May 10, 2006 8:51 pm
sergei wrote:This problem can be becuase of the bad ground either in the engine bay area or speedo area, check if all screws behind speedo are tight and not corroded.
Ok, thank you !
Wolf_Tm250
Wolf_Tm250
Postby Grrrrrrr! » Wed May 10, 2006 8:58 pm
Had this problem with my old gearbox, put a new one in and the problem went away. The sender looked fine, no damaged teeth or anything but something inside it must have been faulty cos the new one has been been fine for the last 770K kms.
if you can find someone with the same gearbox try swapping them over and seeing what happens (i assume they aren't too hard to get at on a gt4?)
Grrrrrrr!
Postby Wolf_Tm250 » Fri May 12, 2006 8:57 am
Grrrrrrr! wrote:Had this problem with my old gearbox, put a new one in and the problem went away. The sender looked fine, no damaged teeth or anything but something inside it must have been faulty cos the new one has been been fine for the last 770K kms.
Ahhhhh.................. ok !
:evil: :evil: :evil: it's damned very hard to get at it........ :(
Thank you..
Wolf_Tm250
Wolf_Tm250
