AC delete on 4AGE Black top
Postby 4000GT » Sat May 13, 2006 1:11 am
Anyone done it? The silver top is out of the car and black top about to go in and I want to delete the AC compressor. But how do you tension the belt? What have people done?
TIA.
Supra MKIV Aerotop (UZA80FTE conversion) STATUS: 3 months to go!
Nitrous is like a hot chick with a STD..... you know you wanna hit it, but you are afraid of the consequences.....
Free online business and reporting tools visit www.e-solver.com
4000GT
Postby Mr Revhead » Sat May 13, 2006 1:36 am
get rough and rangi!
i know of such a set up, ill see if i can get pics this weekend
Postby RedMist » Sat May 13, 2006 8:43 am
Modify the PS pump mount so that it can be used as a tensioner.
If Revhead is talking about using the pull idler pulley as a push, you end up bending the shaft.... I did.
Anyway modifying the PS pump mount is much tidyier, and removes the weight of the idler and mount as well.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby trueno_20v » Sat May 13, 2006 9:50 am
i just took the ac pump and the tensioner off and brought a real short belt straight from the crank pulley to the ps, then i took the top bolt out of the ps pump and it then swivels on the bottom bolt as a tensioner..works good :lol:
ADMIN EDIT: signature too large
trueno_20v
Postby sergei » Sat May 13, 2006 10:38 am
or you could go to pick a part and find NZ-new AE82 4AGE and borrow the tensioner and tensioner bracket, or contact Mr Revhead to source you one, as these cars came without AC and have right tensioner for the job.
Postby Mr Revhead » Sat May 13, 2006 11:36 am
the one i mean uses the pump as the tensioner, has a threaded adjustment on the back of it that pushes against the block. crude, but works
anyway looks like you have a few options :D
Postby 4000GT » Sun May 14, 2006 4:21 pm
Mr Revhead wrote:the one i mean uses the pump as the tensioner, has a threaded adjustment on the back of it that pushes against the block. crude, but works
Warwick, could you please price up the tensioner and tensioner bracket for a non AC black top? We put it in last night, just need to get the longer throttle cable and a couple of exhaust gaskets in the tune time.
4000GT
Postby gepsk8 » Tue May 16, 2006 12:16 am
what bout a gti (ae92 smallport) pulley and adjuster? then u can adjust ur belts if they start slipping. whats a new set of adjuster pulley and bracket worth revhead? pm if u need chassic numbers
gepsk8
Postby 4000GT » Sun May 21, 2006 11:06 am
sergei wrote:or you could go to pick a part and find NZ-new AE82 4AGE and borrow the tensioner and tensioner bracket, or contact Mr Revhead to source you one, as these cars came without AC and have right tensioner for the job.
Looks like I am going for this option. I will try the wreckers... or if anyone is wrecking one, please let me know.
4000GT
Postby neo » Sun May 21, 2006 11:02 pm
I couldnt find any 4a corollas with ac + ps at the wreckers, so i went DIY..
The PS bracket has 3 bolts, undo one so that the 2 remaining make a hinge. Weld up an adjuster (using old long bolt from the tensioner from the ac) and attach it using the top two bolts that secure the ps unit together..
Wa-la, I should be able to supply pics later this week when I return to the car.
neo
