ae101 ecu and speedcut question
Postby Dirtbag » Fri May 12, 2006 12:40 pm
How do you get to a ae101 ecu? Ive tried unscrewing lotsa panels but they dont seem to come off, are there any hidden screws? And does the ae101 stock ecu have a speed cut? I heard there is one around 200kph?
AE101 GT-APEX Superstrut
My profile!
Dirtbag
Postby sergei » Fri May 12, 2006 1:13 pm
185Km/h is the normal speed cut. needle will go way past that but the speedo in that range is highly innacurate.
There is no need to remove any panels at all, just remove the drivers foot rest, the ecu is held by 2(?) nuts it can be pulled out from opposite side of the drivers foot rest, through opening wich is covered by carpet...
Postby KinLoud » Fri May 12, 2006 2:40 pm
To remove drivers footrest use a big screwdriver to undo the 2 plastic screws. They look a bit like part of the footrest.
To remove the ECU you will need to pull back the carpet on the drivers side of the centre console, unplug the ecu and undo the 1 or 2 screws holding it into it's cradle. Then slide it out towards the drivers footwell.
Ken
Ham
021 408 863
Postby Dirtbag » Fri May 12, 2006 4:36 pm
Cheers boss, that was easy
My profile!
Dirtbag
Postby pidge » Fri May 12, 2006 11:16 pm
sergei wrote:185Km/h is the normal speed cut. needle will go way past that but the speedo in that range is highly innacurate.
Having seen where the needle ends up at speed cut on a AE101 GT-Z, I'd agree with that, assuming the speed cut is at 185kmph. I thought it was closer to 200kmph though...
pidge
Postby Mr Revhead » Fri May 12, 2006 11:31 pm
same, i remember reading around early 90s that they were lowering the "volantary" speed cut from 200ish to 180
Postby sergei » Sat May 13, 2006 12:56 am
I had it on GPS. the needle was in about 210 region. GPS read 185..
P.S. it was done in controlled conditions.
Postby Mr Revhead » Sat May 13, 2006 12:59 am
oh well, doesnt matter. in a stock ae101 your just as fcuked at 185 as you are at 200 if anything happens
Postby slighty_sykotic » Sat May 13, 2006 9:39 am
My speedo goes to 220ish at speedcut :D
When you work it out with revs, i got a answer of 186km.
I guess if you really wanted to take it out you could cut the speed wire, but you would have to make up a thingee to generate a pulse for the ecu, otherwise it would drop into fail safe would it not?
--Sykotic
slighty_sykotic
Postby deaf_rattle » Sat May 13, 2006 10:21 am
the ecu without the speed input will only rev out to 7800rpm i believe.
Postby slighty_sykotic » Sat May 13, 2006 4:54 pm
Thats why you have to fake the signal :)
slighty_sykotic
Postby Lloyd » Sat May 13, 2006 5:07 pm
Didn't seem to matter on AE101 GTZ just cutting speed sensor wire. Tried one with a switch in the line and with the wire off it means no speed cut, but the check light came on after 5 or 6 seconds of flicking the switch. No noticable drop in engine performance, though it saying that I doubt the engine would be up in the rev limit region in 5th anyway. Light went away with switch back to normal
Postby Dirtbag » Sat May 13, 2006 5:13 pm
Yea, just installed my rsm, and it has the ability to cut the speed sensor,but having never reached it anyway I thought Id ask what it was, didnt install the speed cut in the end, doubt id reach 185km/h anytime either!
My profile!
Dirtbag
Postby pidge » Sat May 13, 2006 10:21 pm
slighty_sykotic wrote:My speedo goes to 220ish at speedcut :D
Assuming the Rev counter and speedo are accurate around 3300rpm and 100kmph respectively (at least my GT-Z seems to be doing about 3300rpm at 100kmph), and assuming you can get to the 7800 rev limit in fifth gear, you'd be doing 230+ kmph. :D :( 8O :? :roll: (pick one)
pidge
Postby Dirtbag » Sat May 13, 2006 10:27 pm
Yea i was reading about the maximum speed on a 20v silvertop with the stock gearbox, at redline in 5th it would be going jst over 250km/h, but then the car doesnt have enough power to overcome drag to get there
My profile!
Dirtbag
Postby AceSniper » Sun May 14, 2006 10:40 am
http://images.google.co.nz/imgres?imgur ... s%26sa%3DN
check the graphs out half way down the page
AceSniper
Postby Dirtbag » Sun May 14, 2006 1:29 pm
there we go! :)
My profile!
Dirtbag
Postby AceSniper » Sun May 14, 2006 1:42 pm
I can confirm a silvertop can do 230 :oops:
AceSniper
Postby Mr Revhead » Sun May 14, 2006 1:48 pm
feeling the throttle response and reserve they have at cutout id beleive that
Postby Dirtbag » Sun May 14, 2006 1:49 pm
230? wow.... thats quick 8O the car have any mods?
My profile!
Dirtbag
