4age bluetop issues
4age bluetop issues
Postby rwd_mayhem » Fri May 12, 2006 4:04 pm
just got myself an 86 celica fwd and it has a bluetop 4age TVIS, when i put my foot down it sort of cuts out for a second jerks and then starts to take off, this also happens when changing gears under full acceleration, whats the problem? hows it fixed?
also just today, only the once when i floored it the revs went down instead of up, i found that very strange and it fixed itself after 1 minute and went back to normal.
current: 1975 Valiant Regel
rwd_mayhem
Postby kingcorolla » Fri May 12, 2006 4:42 pm
cap/rotor/leads/plugs?
mite also be a dinky tps. mines also suspicious i give it a tap with the screwdriver for minor adjustment sometimes clears it up (not recommended)
check basics first, could be incorrect/faulty plugs? lead? cracked cap?
1983 Carina AA63 4age
kingcorolla
Postby rwd_mayhem » Fri May 12, 2006 7:48 pm
yea ill replace all that and hopefully it works,
what is tps? im new to the whole 4age thing lol.
its really slow under 4000rpm too if that helps.
could it be computer problems? i really hope not.
rwd_mayhem
Postby 2LTR Rona » Fri May 12, 2006 7:59 pm
Check the throttle butterfly as well.
When I had the head & everything else off doing the CAM belt etc I found a build up of what I assume was carbon, end result was that it caused the butterfly to sick when ever it felt like it, after a light sand this was resolved.
Once all back in the hesitation was gone
2002 Altezza, 1974 KE25
2LTR Rona
Postby l1ttle_d3vil » Sat May 13, 2006 4:13 pm
had a similar thing with my car after the conversion, but it was my dizzy wiring which was faulty. may not be your wiring, but your dizzy may be getting the wrong information/sending the wrong signals as mine was.
Postby Ae92 Levin » Sat May 13, 2006 7:28 pm
It could be really slow under 4000 due to the TVIS butterflys being stuck open or removed (between inlet manifold and head)...
Ae92 Levin
Red/blacktop bigport 4age (lotsa kays, still goes hard!)HKS Mushroom filter with Bunnings cold air induction ;) 4-1 extractors and two inch all the way thru, cat removed Oil catch can Aftermarket front strut brace
Monroe GT Gas shocks and struts with nolathane bushings
Anyone want to buy? just email me.
Ae92 Levin
Postby Ae92typeX » Sun May 14, 2006 1:14 am
Could feplace the fuel filter also- they can cause a bit of hesitation/cutouts when getting on in age and a little clogged
Ae92typeX
Postby rwd_mayhem » Sun May 14, 2006 4:36 pm
i did the plugs, leads, air filter, cleaned out the throttle body and it has improved it a little bit, but still a bit of a hesitation, maybe its the way im driving. ill have to do the fuel filter and see what happens
rwd_mayhem
