Temp Gauge problems?
Postby ollieboy » Mon May 15, 2006 11:56 pm
In my car it shows the temperature as above 250 degrees before the cars even started and it doesn't change when warmed up. Could this be a sensor problem or gauge? Or even earth? Is there an easy way to check which? If sensor can I use any replacement sensor? Its some aftermarket gauge, I can't see a name on it but I have seen them at supercheap before.
I'm stumped.
Cheers in advanced
Ollie
ollieboy
Postby ollieboy » Wed May 17, 2006 12:45 am
Bump :)
ollieboy
Postby ollieboy » Thu May 18, 2006 12:22 am
Anyone?
ollieboy
Postby slighty_sykotic » Thu May 18, 2006 12:52 am
Most of those guages go up with resistance to ground going down.
Ie, if its way up, then the sensor wire is getting a ground signal.
Look for a short, or where it connects to the sensor, is a strand of wire touching a place its not meant to?
--Sykotic
slighty_sykotic
Postby ollieboy » Thu May 18, 2006 7:23 pm
Cheers will check it out.
ollieboy
