Does anyone have Autospeed subscription?
Postby WanaGo » Sun May 21, 2006 10:35 pm
Hey,
Does anyone have an Autospeed subscription, and can login and download articles etc?
There is an article on the Caldina GT-T and one of the 3S series engine. Was just wanting to know if someone had a sub already and could please grab it for me.
Issue 373 (22nd March 06) and Issue 370 (6th March 06)
EDIT: http://autospeed.drive.com.au/cms/A_2843/article.html
http://autospeed.drive.com.au/cms/A_2820/article.html
Thanks
WanaGo
'98 Toyota Caldina GT-T
'97 Kawasaki ZX9R Motorcycle (900cc sportsbike 142HP)
Bike Pics: www.taktik.co.nz/bike/mybike/
WanaGo
Postby WanaGo » Sun May 21, 2006 11:44 pm
Couldnt wait! Dammit!
Paid the subscription for these articles.
Here they are if anyone else is interested.
http://www.taktik.co.nz/caldina/Toyota_3s.pdf
http://www.taktik.co.nz/caldina/Toyota_CaldinaGTT99.pdf
WanaGo
WanaGo
Postby HERGTT » Sun May 21, 2006 11:52 pm
Hey great - thanx for that :D
HERGTT
Postby WanaGo » Sun May 21, 2006 11:54 pm
No problem.
Thought they would be a bit.... longer, than they are. ah well.
WanaGo
WanaGo
Postby WanaGo » Mon May 22, 2006 12:07 am
When someone reads that one on the 3S engine, down the bottom it talks about the Caldina GT-T 3S-GTE engine.... It talks about the 97 version, and then about the 02 version. It says the 02 version came out with the Gen IV engine.... isnt the 97 and up versions Gen IV too, or am I mistaken?
The ’97 ST215 Caldina also benefited from VVTi and 11:1 comp. The AWD GT version kicks out 140kW and 206Nm and, later, the ST210 front-drive scored the same engine. And, to make the Caldina even more appealing, a GT-T version was released with turbocharged 3S-GTE grunt. Curiously, the Caldina GT-T’s 3S-GTE puts out slightly more power than the MR-2 or GT-4 - 191kW and 324Nm.
And the action kept coming during 1998... etc etc etc
In the late ’02 Caldina GT-T (ST256) you’ll find a fourth generation 3S-GTE boasting direct-fire ignition, a new intake manifold, revised engine internals and an integrated exhaust manifold/turbine housing. Curiously, you won’t find the VVTi system as fitted to atmo models. Power? A range-topping 191kW and 324Nm.
WanaGo
WanaGo
Postby WanaGo » Mon May 22, 2006 12:11 am
oh and does the 3S-GTE have VVTI etc, or does only the 3S-GE? (or neither?)....
Excuse my ignorance, still trying to find info.
WanaGo
WanaGo
Postby Alex B » Mon May 22, 2006 12:12 am
Late model 3s-ge only afaik.
Postby WanaGo » Mon May 22, 2006 12:20 am
Found this on 6gc.net site, for the celica.
JDM Engine Specifications
In Japan, the '94-98 Toyota Celica came with one of three engines. The SS-I came with the 3S-FE engine, the SS-II and SS-III came with the 3S-GE engine, and the GT-4 was powered by the 3S-GTE engine. In 1996, the 3S-FE engine was improved slightly to increase fuel economy and decrease vibrating noises. In 1997, Toyota introduced VVT-i to the 3S-GE engine for the 1998 Celica, which increased horsepower and torque substantially, and improved fuel economy. You can identify 3S-GE engines with VVT-i, because they have a red valve cover that says "Beams." The 3S-FE runs optimally on regular octane unleaded gasoline, but the more performance-oriented 3S-GE and 3S-GTE engines require premium octane unleaded gasoline.
Some people wonder if the 3S-GE engine will be the same as the 3S-GTE if you add a turbo to it. It will not be the same. The 3S-GE engine with VVT-i has a compression ratio of 11.0:1 and the 3S-GE without VVT-i has a compression ratio of 10.3:1, while the 3S-GTE engine has a compression ratio of 8.5:1. So to add a turbo to the 3S-GE, you would need to lower the compression through the use of internal engine parts. Below are the specifications for these engines.
Engine: 3S-FE 3S-GE 3S-GTE
Cylinders: 4 4 4
Displacement: 2.0 liters 2.0 liters 2.0 liters
Type: DOHC DOHC VVT-i1 DOHC
Horsepower: 138@6000 RPM 197@7000 RPM2 251@6000 RPM
Torque:(lbs.-ft.) 138@4400 RPM 152@6000 RPM3 225@4000 RPM
Forced Induction: None None Turbo
1 - In 1994 through 1997 Celicas, the 3S-GE did not have VVT-i.
2 - In 1994 through 1997 Celicas, the 3S-GE only produced 177 hp@7000 rpm.
3 - In 1994 through 1997 Celicas, the 3S-GE only produced 142 lbs.-ft. of torque@4800 rpm.
WanaGo
WanaGo
Postby MasCam » Mon May 22, 2006 8:18 am
Yeah there are a few mistakes in the 3S article and the GT-T one is just a small road test.
ps yes I have an autospeed subscription.
Invercargill hmmm I'll be down there in a couple of weeks
Chris
MasCam
Postby WanaGo » Mon May 22, 2006 8:21 am
Cool.
Yeah its not a bad place. Only been down here 5 months now, moved down for work after I graduated. Was in Palmerston North before that.
'Tis starting to get chilli though :?
WanaGo
WanaGo
Postby Stealer Of Souls » Mon May 22, 2006 9:21 am
And if you'd just waited till this morning I could've done them for ya!
'86 AE85.5 Levin
Stealer Of Souls
Postby WanaGo » Mon May 22, 2006 6:12 pm
Yeah my bad :roll:
Impatience got the better of me.
Thanks for what you potentially would have done though!
WanaGo
WanaGo
