How do I get the factory air filter out on my mr2? I'm pretty sure it needs to be replaced.
AJz wrote:
the plug from what i can see is your intake temp sensor as its not AFM.
It should be held in the box by a little grommet, pull it out if it gets in the way, jsut remember to put it back in.
map sensor?
map sensor?
Air intake temp sensor
map sensor?
thats right its a mr2
heat issues, not that the top mounts super cool tho
map sensor?
