Caldina Sounds...
Caldina Sounds...
Postby ADIKTD » Tue Jun 13, 2006 8:39 pm
I was thinking about replacing the factory speakers in the doors of my 98 Caldina and am really keen to know what size they are so I can buy them now, install them later and without taking the door panels off.. so if anyone could please help with speaker size in inches or cm's that would be wicked! Oh and one more thing... where is my aerial?? so I canmake it better? - thanks in advance!
ADIKTD
Postby 86_rolla » Tue Jun 13, 2006 8:57 pm
if you get components your gonn have to take door panel off anway to wire up cross overs etc etc. Also what is modern speakers have massive mounting depths compared to stock, so spacers might be needed.
Just a warning
Current: EF Honda civic
Ex cars: 2E corolla
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1488
86_rolla
Postby HERGTT » Tue Jun 13, 2006 9:21 pm
We upgrded our sounds recently, our factory fronts were 5 1/4" but we replaced those with 6" components :D
HERGTT
Postby HERGTT » Tue Jun 13, 2006 9:25 pm
As for the aerial, you just need to get a signal booster/amplifier (about $30 from supercheap) - (the aerial is in the rear quarter windows)
HERGTT
Postby HERGTT » Tue Jun 13, 2006 9:27 pm
86_rolla wrote: so spacers might be needed.
Yep we needed spacers - used snwtoys method of using cookie time lids :) works perfectly!
HERGTT
Postby HERGTT » Tue Jun 13, 2006 9:36 pm
OR.....you could do a search and you might find this quite helpful...
viewtopic.php?t=33592&start=0
HERGTT
Postby ADIKTD » Tue Jun 13, 2006 9:39 pm
Awesome.. thanks! just another point... Is it easy to do? Like can I just put 6" speakers in, spacers and put the door panel back on so no-one knows you have more than factory speakers? and does the signal booster go behind the headdeck? Pardon my ignorance! - Cheers
ADIKTD
Postby HERGTT » Tue Jun 13, 2006 9:45 pm
Yep signal booster can go behind head deck.
As for the speaker install - my partner did it for me, and I heard a few nasty remarks along the way so I'm guessing it may get a bit tricky :lol:
But yeah they are now nicely tucked in behind the door panel :D
HERGTT
Postby 86_rolla » Tue Jun 13, 2006 9:49 pm
re: spacers. Ive just installed some fusion comps. what i did was pop the grill out of the speaker cover that came with the speakers and used that as the spacer. Just drill some holes to attache to exsisting speaker mount and then screw speaker in, works a treat and no extra $$
Ex cars: 2E corolla
86_rolla
Postby ADIKTD » Tue Jun 13, 2006 10:11 pm
:) Awesome!! thanks for your help... :D
ADIKTD
Postby snwtoy » Tue Jun 13, 2006 10:58 pm
Regarding the signal booster - I didn't install and additional one, and my reception is AWESOME (aftermarket hu).
There is a factory booster, which you need to connect to the remote wire of your stereo (if you're replacing it). The standard tuner is crap.
snwtoy
Postby ADIKTD » Tue Jun 13, 2006 11:11 pm
Awesome!!where abouts is that found? and what if you have an amp attached to the remote part of your Head deck?
ADIKTD
Postby snwtoy » Sun Jun 25, 2006 8:05 pm
ADIKTD wrote:Awesome!!where abouts is that found? and what if you have an amp attached to the remote part of your Head deck?
Depending on the head deck, you may have a separate 'aerial' output which you can connect to the signal booster. Otherwise you should hook the amp remote and signal booster wires together, and connect to the 'remote' from your deck.
snwtoy
Postby ADIKTD » Sun Jun 25, 2006 9:04 pm
That is awesome!! Thankyou so much!!
ADIKTD
