Blacktop - PS with no AC
Postby Santa'sBoostinSleigh » Wed Jun 14, 2006 11:39 pm
Has anyone got a good solution to a small problem i have come across:
Blacktop motor, removed a/c
this means that the power steering belt is way too long
now i could whack on a shorter belt, but how do you keep it tight?
pics would be great ;)
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby KinLoud » Wed Jun 14, 2006 11:43 pm
I think some people have gutted the aircon leaving only the pulley and front bearing with nothing else left - I have seen it once...
Talk to Ewan (10k20v) as he did it on his mad AE101 fire breathing monster!
(I'll try to sort out the headlight to you tomorrow)
Ken
Ham
021 408 863
Postby Santa'sBoostinSleigh » Wed Jun 14, 2006 11:54 pm
unfortunately i think the blacktop ac pump got a bit damaged during removal, ive got a redtop one if that will work?
(will get ngaere to post your cheque tomorrow - id fully forgotten!)
Santa's Mega Sale
Postby trueno_20v » Thu Jun 15, 2006 10:45 am
What i done was, i took the ac pump off, took the mount it bolted to with the tensioner all off, took the top bolt out of the ps pump so that it swivels on the bottom bolt, went a brought a belt that just fit on when i pushed the ps pump right foward, pulled the ps pump back so that it tightened the belt, then done the bottom bolt up tight, never had a problem since, i can get pics and belt size if you want?
ADMIN EDIT: signature too large
trueno_20v
Postby Santa'sBoostinSleigh » Thu Jun 15, 2006 2:45 pm
yup pics and belt length would be brilliant!
Santa's Mega Sale
Postby Santa'sBoostinSleigh » Thu Jun 15, 2006 11:32 pm
had a play tonight and forgot what you said but thats how im going to do it, plus maybe add a screw/bracket thing that ensures it stays tight
Santa's Mega Sale
Postby slighty_sykotic » Fri Jun 16, 2006 2:28 pm
What I did too :).
But i also added a small bracket between the top mount hole of the PS pump, and the hole in the bracket where it is meant to lock into.
Just got certed a couple of days ago, so all good.
--Sykotic
slighty_sykotic
Postby trueno_20v » Sat Jun 24, 2006 3:24 pm
sorry i forgot about getting you the pics and belt size, i lost the packet it came in which said the length, but i did get numbers off it, 5pk0890 350k5 a.26, go to BNT and tell them those numbers and im sure they will know, heres some pics, the circled bolt is the bottom bolt that the ps pump swivels on to tighten it..
trueno_20v
Re: Blacktop - PS with no AC
Postby possum » Sun Jun 25, 2006 11:08 am
Santa'sBoostinSleigh wrote:Has anyone got a good solution to a small problem i have come across:
An other very easy option, when i did blacktop convertion in my NZ AE82, u know how nz new once didnt had AC pump just a bracket with pulley, so i just swaped them around, NZ new bracket on blacktop, the problem only to get that bracket with pulley, if u licky u'll find it in pickapart
possum
