hi,
im looking at buying a ae101 gtz,
is there anything that i should be looking for that is a common problem?
any other useful info would be apreciated
thanks
crnkin wrote:super strut bushes in the rear
Distrb wrote:crnkin wrote:super strut bushes in the rear
dont you mean the front?
peas wrote:Do the white ones rust out as bad as the AE92's? Both my white 92's have rust around the boot lid and one has just got rust all over it. On the other hand both my black ones havent got any signs of it at all!
I guess that the 101's would be coming to the stage where rust would start to show, so just have a look under the boot lip seal, spare tyre well, drain at front of doors on the bottom and the rear window... I think thats the usual suspects.
sergei wrote:AE101s are made out different steel. They don't rust that much. I have a front guard outside wich has big patch of bare metal, it has been like that for couple of years. Slightly surface rust.
So yeah Parts i have always found it hard to get parts. Now if you have the $$$ then toyota has all the parts you need but the inner CV assembly was going to cost about $1600 from japan, or $300 from the driveshaft center to modify a one.
1998 wrote:I have heard (and ive only heard from one person, but maybe someone else can confirm) that after about '89-'90 toyota used a better primer which wasnt as prone to rust. I have a '90 ae92 which doesnt have any rust, and ive checked for it too. What year are your ae92's peas?
