Hey Guys,
Gen1 Sw20 Turbo.... Im seriously considering getting a cam grind, my question is... whats involved in swapping out the factory cams with a set of grinded factory cams.... is it a major like doing the cam belt?
Ako wrote:Just get a decent turbo + exhaust on it.
Same price, better results, less headaches.
Yes its like a cambelt (well it has to come off afterall to get the new cams in), but more work - and correct me if I'm wrong but you'll need to get things re-shimmed for the new cams?
ATSMATT wrote:I just put my 264s in last night and even with some mild cam tuning the car still idles good. As long as u turn up the idle a little to get rid of the surging caused by the stock IAC motor. Also my car is equipt with the ATS TD06 kit and a ATS fuel railwith stock injectors (stock fuel pressure) and a stock intercooler. I made 289 hp at 11.5 psi. Compared to 275 at 14 psi. My car still retained 11.5 AFR
Mmm, Boost wrote:To remove them yeah, but to put them back in is a bit different. You really need to degree them in for best results.
diss1dent wrote:Can you not find a ct20b for under $500?
Man I sold a steel wheel'd ct20b with 68k's for like $350 about 3 years ago.
