l1ttle_d3vil wrote:• Many, many hours of work
crnkin wrote:Took me 3 hours by myself.
put new sump on (45 mins)
Bolt off old ex, on new manifold (45 mins)
Oil lines on (10 mins max)
Plumbed in intercooler with $40 mild steel and 80 bucks of joiners (30 mins)
away
It takes fark all time, just get the bits you need
CircuitLevin wrote:I know $&#$% all, but I would think the stock injectors will be pushed, and although its a map based ECU, what bar does it read too? Add all the fittings and clamps
1998 wrote:Does that include wiring in new computer? new injectors, new fuel pump, what ever needs done to the engine (forgies/bearings/whatever else is worn)
Need to get a new dumppipe and front exhaust section.
Hours of trouble shooting.
Or did you pay someone to do all that?
Cos those things will take ages.
However I do admit most of my time is wasted $&#$% re fitting.
Manifold took ages to build. tacked one up and it hit all sorts of things (CAS, starter motor, AC pump)
fixed the manifold, tacked the flange on, turbo hit CAS.
fixed that, dump pipe wouldnt fit, had to make big changes
lots of $&#$% aroundtakes ages.
away
Dorift 180 wrote:Having that oil filter explode while going down the motorway.... Priceless.
If your manifold hit all those things, just remember, measure 25 thousand times, cut once. Only thing i needed to do was made a small dent in runner #2 for the oil filter, as it hit for a start.
Dorift 180 wrote:If your manifold hit all those things, just remember, measure 25 thousand times, cut once. Only thing i needed to do was made a small dent in runner #2 for the oil filter, as it hit for a start.
And if the filter hits the runner what happens???...
Kaboom!
Instant retard
