z0ton wrote:Does anyone know what size the bolt holes on the crank pulley are? The ones you use to screw a pulley remover into to get it off. Ive brought a cheap harmonic balancer pulley remover but the bolts that came with it dont fit my crank pulley.
I have a 1991 20V Silvertop and heres a pic of some pulley to show you which holes I mean.
http://www.7ent.com/newmini/images2/7nm6008.jpg
Yeah the inner holes opposite to each other, Take a 10mm head bolt out of your engine bay somewhere and try it in the pulley, if it fits its M6x1.0mm. I think the next common size up would be M8 x 1.25. you need a bunch of old metric bolts you can try, and just take the one that fits to Mitre 10 and match it up.z0ton wrote:You know I mean the little holes ay? So thats their size?
peas wrote:Just in the process of doing this myself and are having issues. Any trick to cracking the nut? The belts and all other parts have been removed and I have tried with a substantial power bar but just end up having any torque taken up by the engine mounts. Is it really a rattle gun only job? If so anyone got a gun and compressor that they want to loanI cant move the car unfortunately.
Worst comes to worst you can get tyre places like beurepaires to come around and blow it off with a 3/4 gun as they have all the gear on their fleet trucks. Way more torque than 1/2 inch guns period. Had to do this the odd time on honda crank bolts as they get Very tight!!peas wrote:I have heard of that method... I have already drained all the fluids from the engine though... is this going to be a major damage issue, considering that it will only be cranked not started and with a bit of luck it will only be SFA of a revolution I would have thought not but expensive if it is! The jappas rotate clockwise with the excetion of a [person of homosexual orientation] manufacturer that we dont mention here...?
peas wrote:Theres no fuel rail on it or anything else really so Im not so worried about it actually starting, just why it wont crank at all!
Proper tool?... I won't hear of it
