manifold fabrication - what to use
Postby l1ttle_d3vil » Fri Jul 07, 2006 8:31 pm
what would be some good advice for making a turbo manifold for vf10 onto 4age, rwd application.
    * what would be an ideal "wall thickness" for the manifold?
    * would would be the ideal "length" of each of the pipes from block to turbo flange? shorter the better? longer the better?
    * whats the best type of material to make these from, just something to get the job done. don't want chrome/polished stuff that costs heaps.
    * would I be able to cut some fwd extractors up and use parts of them for the manifold, or would the material not be right for a turbo manifold?
any other info anyone can add would be much appreciated! and before anyone says, i've already searched and read so these are questions I still need answers to.
-matt[/list]
Re: manifold fabrication - what to use
Postby evil_si » Fri Jul 07, 2006 8:43 pm
l1ttle_d3vil wrote:[list]
*use scheldule 40 steam tube.
*not really an ideal length, just try to keep them all equal.
*mild steel
*cough* rough. get new flanges profile cut, much nicer to work with. you dont want to use thin walled tube for a turbo manifold they just crack and fall apart
evil_si
Postby l1ttle_d3vil » Fri Jul 07, 2006 8:50 pm
sweet. mig welds strong enough?
equal length as in what, within 0.5" or closer?
should anything be heatwrapped for a turbo application? there is wiring nearby, its been fine so far but with a turbo manifold there it'll probably sit a bit closer. do they tend to create much more heat than a N/A engine/manifold, or nothing noticable?
Postby KE20 » Fri Jul 07, 2006 9:19 pm
use steam pipe bends, they like 5mm thick wall , you can get from steel and tube, youll get heaps more heat than a n/a manifold. when you ringing the shit out of it, you can get the manifold glowing orange.
Garage Dori
current cars; , 2JZGE-YN57R Hilux double cab, Ipsum Sport, 1948 Ford F1
prevous cars; JZX81 X2, LX80, , 1JZGTE-JZX81, KE20-3SGTE, KE35-4AGE, KE35-3A, KE30, KE36, TE71, AE85, AE86, KE70 X4, KE20, 1JZGE-VVTI-JZX100, GX90, CT170, VW(beetle) x 5,(Kombi) x 2, mazdas x heaps, +more
KE20
Postby DexGT » Fri Jul 07, 2006 11:58 pm
Yea Schedule 40 weld bends , Mig welding is fine . The Mani I made for my road car has been in service for 80,000 Km now , still going fine 8) .
You want atleast 12mm thick flanges so they don't pull to much with the welds
DexGT
Postby Caveman » Sat Jul 08, 2006 3:22 am
yep scheldule bends from steel and tube for about $3 each. Buy the toyota exhaust gasket to cut the flange, 12mm is a good thickness, hate to be the people that use 8mm flanges, have a hell of a time with it warping.
I wouldnt mig if you have other options, mine is arc welded and has no problems.
Has anyone used scheldule 20 bends? I was going to make another one using 20 bends to save weight, or maybe just go stainless steel?
AW11 Track Toy
Formerly known as 1998
Caveman
Postby l1ttle_d3vil » Sat Jul 08, 2006 11:25 am
1998 wrote:I wouldnt mig if you have other options, mine is arc welded and has no problems.
i've got any options I want, tig, mig, arc, gas...
just some of them I could probably weld, some of them I would need someone else to do...so I would prefer to stick to mig so I don't have to wait until someone else can do it for me...but I suppose I could learn the others too :roll:
Postby QikStarlie » Sat Jul 08, 2006 11:57 am
mig will be fine, long is its a half decent one. crank the heat up and bevel the pipes
QikStarlie
Postby evil_si » Sat Jul 08, 2006 2:34 pm
i tig weld mine.
other wise would mig over arc.
if you are mig or arc prep the joins properly clean off the black paint and grind a bigger 'V'
evil_si
Postby Caveman » Sat Jul 08, 2006 7:49 pm
Yep everyone has opinions on weld types. At the end of the day the one you are most comfortable with will probably give the best job.
I can only arc weld well. Why do I prefer it? I find its easier to get good penetration and less prone fusion/oxidising.
Mig will be fine if you are good at it but I find its harder to get good penetration.
AW11 Track Toy
Caveman
Postby crnkin » Sat Jul 08, 2006 8:14 pm
1998 wrote:I find its harder to get good penetration.
hehe[/b]
deaf_homo "currrently yes"
crnkin
Postby KE20 » Fri Jul 14, 2006 6:10 pm
i find arc is best, espeacialy on thick steel stuff as you get max penotration, where mig ones i had used have cracked.
Garage Dori
KE20
