Ae92typeX wrote:Whilst I dont have any for blacktops in particular, there is heaps of written material out there which shows the benefits of intake trumpets and length tuning on NA engines. The black top would be no different.
TRD001 wrote:Im currently getting a 4AGE B/T Installed with 90mm aftermarket trumpets with Independent filters with inner springs.
Sounds Mean, pretty ricey too.
RedMist wrote:I spent some time studying helmholtz frequencies before installing my aftermarket trumpets and airbox. However In all honesty the ones I selected (off trademe) I'm a little dissapointed in. They are the correct Helmholtz length for my rev range (120mm total length) but they dont have a big enough taper and only rotate 90 degrees at the bellmouth.
Unfortunately I couldnt test before and after trumpet installation as I was pressed for dyno time. 177.5bhp at the wheels, and still needed to be run in.
RedMist wrote:Bunderson engine has cost about 8k... I dont add it up in case the wife finds out about how much I spend. Budget for my V6 1600 is 11k, so that project is on hold for a weeeee while.
Its far from the original 16 valve bluetop engine it once started out to be. Cams, shim under, arias OS pistons, TRD bearings throughout, silvertop TB's (keep velocity up) and one tonne of head work.
132bhp is incidentally what I made from my blacktop with KnN, custom exhaust and Link ECU. Made 123 and 125 on my silvertops.
QikStarlie wrote:anyone played with the idea of variable length runners? even it was just a 2 stage setup, 2 Helmholtz points is better than one. i wont say anymore
Users browsing this forum: No registered users and 36 guests
