running exhaust off external wastegate
Re: running exhaust off external wastegate
Postby Dell'Orto » Sun Jul 09, 2006 10:03 pm
deaf_rattle wrote:will i need a flexi pipe? i thought that was just for fwd and 4wd, because of the way the engine moves.
my exhaust doesnt have a flexi joint in it.
You only need it for the wastegate pipe when it joins back into the exhaust, as the sudden rush of exhaust gas makes them flex, then contract as they cool down again.
Postby deaf_rattle » Sun Jul 09, 2006 10:48 pm
ah yep, that makes sence. so if it was a seperate exhaust pipe, it should be fine without a flexi?
Postby BBBrad » Tue Jul 11, 2006 12:40 am
Do you guys watch performance car tv, esp the street car challenges? Ive seen a few cars go through the wof section of the competetion with externals pointing straight down, no probs at all. They seem to be quite happy to pass them on national tv.
My new car...99 mr-s
BBBrad
Postby postfach » Wed Jul 12, 2006 7:00 pm
im quite sure that was one of the reasons they lost points in that segment
postfach
Postby BBBrad » Wed Jul 12, 2006 7:30 pm
Pretty sure the 300kw mirage didnt loose any due to it.
BBBrad
Postby bluemaumau » Wed Jul 12, 2006 8:47 pm
ok i havnt read all of the posts. but ive seen some cars with a separate exhaust (for the wastegate)
so it wouldnt be super original, and surely itll just cost more and wont have any gains?
or would it?? :oops:
Postby deaf_rattle » Wed Jul 12, 2006 8:49 pm
hey dude.
there are some cars out there with similar set ups to how i want to do this.
but yeah i have a couple of reasons for wanting to do it like this.
i dont want the noise, and would like a seperate pipe for when i need to remove the turbo, manifold etc.
much easier if downpipe and wastegate pipe is seperate
should get quite a nice sound out of it like this too
Postby bluemaumau » Wed Jul 12, 2006 8:53 pm
deaf_rattle wrote:hey dude.
true never thought about that, i change my vote, do it. even if it just gets to the rear axle regoin itll sound way different too 2 feet of pipe.! :lol:
what size piping would you need to run?
Postby UZZ30 » Fri Jul 21, 2006 2:46 am
deaf_rattle wrote: lukey muffler
Just curious to what model of lukey muffler do you have? How loud does it sound in general around idle?
I bought a couple a while back for a project but never got around to have them fitted. However planning to use one for a new project so yeah, wondering what they actually perform like?
UZZ30
Postby deaf_rattle » Fri Jul 21, 2006 7:35 am
Hi, i used to have the lukey muffler at the exit of the exhaust and a straight through resonator half way up the exhaust, it was fairly loud with that when i was running the n/a straight 6. not long before the turbo conversion i got rid of the resonator and put an action dan cannon style muffler at the rear and the lukey muffler where my resonator was.
the torque felt slightly better down low, and it was much quieter.
it gave a very nice sound with this set up.
it was even quieter with the turbo motor, and dont think it would give any problems at wof time once its back on the road
Postby Ako » Fri Jul 21, 2006 10:24 am
Yes, thats a good and legal way to do things.
Good luck to anyone who tries to make it vent by free - revving it, so you won't fail on noise. And since its' behind the passenger compartment, its legal in that respect too.
I've seen a couple of cars done that way, it sounds quite cool. From inside the car it sounds tough, from outside it just sounds feral (wether you like that or not is another story).
One of the exhaust shops down here refuses to do externals venting downwards, they will run the pipe to the back of the car however.
For extra cool points, I suggest having the wastegate pipe run out the bonnet, and up the "a" pillar. At the top of it, have a little flapper on it, like a truck. That way you don't need a boost gauge - just watch how much the flap opens through the sunroof :lol:
Ako
