ST205 Boost pressure without TVSV
Postby sergei » Fri Jul 14, 2006 12:17 pm
What is the stock boost pressure on ST205 (WRC) and what is the pressure with TVSV (boost control solenoid) disabled?
Tried searching and ended up with 1.0-1.2bar range, and 0.75bar with TVSV disabled. Can some one cofirm this?
Postby RunningRich » Fri Jul 14, 2006 12:52 pm
My ST205 has had the boost control solenoid removed and the pipe blocked. The actuator alone keeps it around 0.5 bar (7ish psi).
My Profec settings above that are of course irrelevant to stock cars.
Richard
http://gtfour.supras.org.nz
RunningRich
Postby sergei » Fri Jul 14, 2006 4:20 pm
The thing why I am asking, I've tried on the bench to apply pressure to wastegate acutator and observe how much it does open. On my steel "CT20b" it opened fully (~70degrees to turbo) at about 1bar. With 0.5 bar I only got ~30 odd degrees of opening..
Postby sergei » Thu Jul 20, 2006 12:01 am
I just took out my celica for a drive for first time with new turbo, I got ~1Bar boost with boost controller off, and hose to TVSV blocked... Is this normal?
Turbo is steel CT20b brand new.
Postby RunningRich » Thu Jul 20, 2006 8:40 am
sergei wrote:I just took out my celica for a drive for first time with new turbo, I got ~1Bar boost with boost controller off, and hose to TVSV blocked... Is this normal?
Sounds high. Like I said, I get around 0.5 bar, which does creep up to 0.8-0.9 at higher 5000+ rpm in higher gears.
Richard
RunningRich
Postby sergei » Thu Jul 20, 2006 9:20 am
i'm using xspower down pipe, I've checked if it is not iterfering with wastegate operation (it is not)... I'll see if I have boost creep problem on higher gear.
Postby TRDPWR » Mon Aug 28, 2006 10:54 am
i recently bought a st205 wrc and it came running 13psi not sure if that is factory for a wrc of not the previous owner said he never changed it.
TRDPWR
Postby sergei » Mon Aug 28, 2006 11:26 am
this is not boost creep, as it does not goes higher than 13psi in any gear. My boost peaks up till 16-18psi (depends what setting I use) as because scramble function of the EBC, and then levels off at 13psi (with gain 0). if I turn off EBC turbo does not spool as fast but has 13psi flat...
With scramble function boost is almost instantenious. 4th gear on motorway is very scary...
