Getting a rebuilt 4age for the corolla (ae82). Standard bluetop.
Engine in it seems to have dropped a valve. What are some things to look for/replace when swapping in a rebuilt motor? New motor already has new cambelt/seals etc.
What sort of oil is best for running in a new motor? How long should it be in there for? I have heard things like, use basic mineral oil for a couple of hundred kays, replace with more mineral oil for another 1000 or so kms, then do another oil change with semi-synth? That sound about right?
Was also going to do coolant, clutch (putting in a new oem clutch), gearbox oil as well...
Cheers in advance.
