Bazda Vs. matt dunn??
Postby Paulio » Sun Jul 23, 2006 5:35 pm
deaf_rattle wrote:
IH8TEC wrote:cutties and no cert, i dont know many dodgy wof guys that will give you a wof for that. :?
even if there was, why would you drive with a car with cut springs?
muppets
i didn't know they were too short for the shock. only costs $50 or something to shorten the shocks so its all good. gives it nice handling in the front anyway.
paul
Paulio
Postby Lith » Sun Jul 23, 2006 5:36 pm
Mr Revhead wrote:i can quite honestly say that every turbo honda iv seen with my own eyes has been no where near as good as an equiv toyota :?
and blow up a hell of a lot more often
Bollux. A lot of turbo Hondas in NZ have been done rangi by people who want "turbs vtex y0", and often on stock compression which leaves very little margain for error.
Ones that have the bottom end made boost friendly take (as you'd expect) a shit load of punishment - and go VERY hard. I know a few people who have turbo Hondas even on the stock motors which are nastier than any Toyota I have been in (yes, I've been in JZA80 TT Supras) running naff all boost.
When you look at something like the 10s Integra down south, that motor has been going strong - it is running a turbo friendly bottom end (yes, low compression)... its the vastly superior head design which is behind the higher power on lower boost.
Lith
Postby Paulio » Sun Jul 23, 2006 5:40 pm
Bazda wrote:hey
The guy you bought this off said it was rebuilt etc only done XXX kms, why r u already pulling it apart???
im sure it was back in '03 when it was rebuilt last. smoked the rings anyway, just pulled it down today.
paul
Paulio
Postby flygt4 » Sun Jul 23, 2006 5:42 pm
it would make sense that the head design had a lot to do with it ,they seem to consistently make more power n/a and the difference would be exaggerated with forced induction.
theres also a shitload of other things to consider as well,such as size of the turbocharger chosen. just a shame they come in such ugly cars :wink:
flygt4
Postby Paulio » Sun Jul 23, 2006 5:52 pm
most hondas arent my cuppa tea but when they're worked good, they can be pretty fking sick. i've seen it!
paul
Paulio
Postby Bazda » Sun Jul 23, 2006 6:10 pm
BBBrad wrote:Sorry for bringing up an old subject. Just that there was mentioning earlier about the 10 sec honda down south, then I remembered the locked thread on "turbo 4age vs turbo vtec". I then had a look over at the honda site....anyone read what theyve been saying? Seems like they think that 330wkw @ 27psi is a joke.
Why do honda motors seem to make a whole heap more power at the same boost???
if you put the same turbo on a b18c same compression etc I think power levels would be very similar. Also my compression is around 7.85:1.
Also honda cams are much more agressive as well in standard form.
Postby Lith » Sun Jul 23, 2006 9:45 pm
Bazda wrote:if you put the same turbo on a b18c same compression etc I think power levels would be very similar. Also my compression is around 7.85:1.
Yep - I'd agree with that, depending on the efficiency map etc. You'd need less boost to make the same power - but seeing as you'd be running more boost on yours, it SHOULD fatten up the midrange as well.
The B18C is likely to operate in a slightly different area of the compressor's efficiency due to it being able to go to higher airflow levels for a given pressure ratio.
Lith
Postby 4000GT » Mon Jul 24, 2006 8:19 am
That honda is Bruce's car. He made 430WHP at 18psi. He since got a job for Stone Brothers racing development in Aussie so isnt in NZ anymore. He is a very humble guy. I think from meory he had a Precision TO4E with a 60 trim wheel and .63 exhaust A/R.
Supra MKIV Aerotop (UZA80FTE conversion) STATUS: 3 months to go!
Nitrous is like a hot chick with a STD..... you know you wanna hit it, but you are afraid of the consequences.....
Free online business and reporting tools visit www.e-solver.com
4000GT
