Heating ideas
Heating ideas
Postby ollieboy » Sun Jul 23, 2006 6:36 pm
My brother has and 89 familia. The heater doesn't work and its bloody cold down here, we tried flushing out the heater core and the hoses but we are going to have to remove the dashboard to do it properly. Its a crap car and we don't want to waste our time on it so we were thinking what other ways can you heat a car.
Any ideas would be appreciated.
Ollie
ollieboy
Postby TrouserFxGt » Sun Jul 23, 2006 7:00 pm
Open door, pour in petrol, stand back, throw in match.
Quite effective.
Alcohol, The cause of and solution to all lifes problems.
H J Simpson.
TrouserFxGt
Postby flat_0ut » Sun Jul 23, 2006 8:33 pm
bring a battery heater :lol:
flat_0ut
Postby summin » Wed Jul 26, 2006 7:20 pm
Wear a jumper
summin
Postby CozmoNz » Wed Jul 26, 2006 7:24 pm
figure out excactly whats the problem
coolant system operating fine?
heater core receiving water?
heater core valve blocked?
heater core blocked?
heater controls working?
then fix it...
Rayne For President!
CozmoNz
Re: Heating ideas
Postby flat_0ut » Wed Jul 26, 2006 10:13 pm
ollieboy wrote:Its a crap car and we don't want to waste our time on it.
flat_0ut
Postby Ae92typeX » Wed Jul 26, 2006 10:37 pm
CozmoNz wrote:...
if it flushed through fine, which Im assuming it did since you say you did this, I would look at the two above. may just be the cable to the valve/tap from the controls. Had this issue on the aw11.
not much hassle, and if too much then yeah, put more clothes on lol.
Ae92typeX
Postby gmacrae » Wed Jul 26, 2006 11:49 pm
should be able to find some cheap 12v hair dryers somewhere, for camping n shit. Dont even have to wait for the engine to warm up then :wink:
gmacrae
Postby Jebus » Wed Jul 26, 2006 11:54 pm
Masturbate every time you get into the car.
Jebus
Postby ollieboy » Thu Jul 27, 2006 12:29 am
Yeah the heater core is blocked, but to unblock it we need to remove the dash and its too much hassle so we wanted some other method. Will double check to see if it is heater controls though cheers.
ollieboy
Postby Caveman » Thu Jul 27, 2006 12:39 am
Cut a hole in your floor and exhaust (que grinder) and duct a 90 degree from your exhaust to your cabin.
Thats if your too fat and lazy to do the job properly.
AW11 Track Toy
Formerly known as 1998
Caveman
Postby ollieboy » Thu Jul 27, 2006 12:52 am
Its not that I'm lazy (much), but its not worth doing much to the car, its getting near the end of its life.
ollieboy
Postby GTCRSHR » Thu Jul 27, 2006 10:15 am
buy a flask and put coffee in it :P
Nothing to see here ...
GTCRSHR
Postby 85AW20v » Mon Jul 31, 2006 10:45 pm
Make sure the thermostat is working as well. Just flush the core using the heater hoses off the block - no need to pull the dash out.
See ya
Simon
85 MR2 20v
85AW20v
Users browsing this forum: Bing [Bot] and 16 guests
