oil catch can
oil catch can
Postby phat_levin » Wed Jul 26, 2006 11:09 pm
am thinking of getting one of these for my ae101 trueno, would it really do much for me? and are the ones with filters best or what? and what is this i have heard about 'baffling' them with steel wool?????? :?
phat_levin
Postby RS13 » Wed Jul 26, 2006 11:17 pm
Baffling with steel wool helps with catching the oil as the oil vapour passes through it.
They're ok, if you set them up properly they assist with preventing detonation (as oil vapour slightly lowers octane), and can reduce oil smoke from the exhaust. The can removes the oil from the crankcase vapour, and if your car has done a lot of km's, and suffers from oily chuff (positive crankcase pressure due to worn rings), they're fairly helpful, just remember to regularly empty it.
They're required in motorsport, to prevent or reduce "oil-downs" due to internal failures venting oil into the intake. I believe all cars up to 2000cc require at least a 2 litre can, and anything above at least 2.5l.. and unfortunately the cheap "chrome" trademe ones are normally only of 1 to 1.5L capacity.. so only good for road use.
Hope this helps! :)
RS13
Postby Jazza » Wed Jul 26, 2006 11:32 pm
Coke bottle au, i swear, best idea
1996 Curren - On Tardme
1992.5 EG Civic - 101kw@wheels. WTB 4x100 6.5in wide rims.
Jazza
Postby Trls250s » Fri Jul 28, 2006 8:02 am
I had the problem with positive crankcase pressure on my FX-GT, i NEEDED a oil catch can otherwise the positive pressure blew my dipstick out under high load (it was a very sick little 4AGE).
Thing i did was go to the warehouse and buy a $8 all metal thermus, drilled 2 holes in it, threaded them to acomidate the valves off a air compressor and siloconed them in. Stuffed the entire thing with steel wool and put one of those mini pod filters on top.
Worked great! I believe its still in my garage after i sold the car. Might be able to post photos if interested.
4a-ge noun for-ay-gee
1600cc of Awesome
AE86 noun aye-ee-ate-six
Rusty Corolla
www.GARAGEDORI.com
Trls250s
Postby wde_bdy » Fri Jul 28, 2006 9:36 am
RS13 wrote:They're required in motorsport, to prevent or reduce "oil-downs" due to internal failures venting oil into the intake. I believe all cars up to 2000cc require at least a 2 litre can, and anything above at least 2.5l.. and unfortunately the cheap "chrome" trademe ones are normally only of 1 to 1.5L capacity.. so only good for road use.
Hope this helps! :)
Up to 2000cc, need 1L can. Over 2000cc needs 2L can. They are not required for motorsport and the minimum sizes only apply if its vented, factory systems (assuming not the old pipe to the ground style) or a plumback system have no requirements. It is only the vented ones as if the motor blows all the oil will pour out the vent and make a big mess and is a fire risk. If its dumped into the intake its less of a risk.
Callum
wde_bdy
Postby Dirtbag » Fri Jul 28, 2006 1:35 pm
http://forums.toyspeed.org.nz/viewtopic.php?p=486190
Bit of info right there, only covered last week
AE101 GT-APEX Superstrut
My profile!
Dirtbag
Postby phat_levin » Fri Jul 28, 2006 9:04 pm
Dirtbag wrote:http://forums.toyspeed.org.nz/viewtopic.php?p=486190
yea read all that but still dont have a clue where i am meant to hook it all up to......
phat_levin
Postby Dirtbag » Fri Jul 28, 2006 9:08 pm
Did you see the pictures? What kind of engine you got? 20V?
You are hooking up pipes like in the pictures to a catch can with a filter ontop, youll need hoses, clamps, the catch can, filter, something to block up the holes on the intake pipe and manifold, and probably some mount so that the catch can actually sits somewhere in the engine bay.
http://forums.toyspeed.org.nz/viewtopic.php?t=48695
thats some real life pics of one hooked up
My profile!
Dirtbag
Postby phat_levin » Fri Jul 28, 2006 10:09 pm
i get all that, the only bit im not sure about is what hole im hooking it up to and what ones im blocking off......its a 20v silver top
phat_levin
Postby Dirtbag » Fri Jul 28, 2006 10:22 pm
If you have a silvertop there are two holes you want to hook up to the catch can, one of on the right hand side of the head, there is a pipe about 8-10mm in diameter that runs from the head to the intake pipe, this is one of the outlets you want to pipe to your catch can, and the hole in the intake pipe needs to be blocked up, second looking at the engine, at the top of the head thers another pipe running from the head to the intake manifold, you need to run a new pipe over to your catch can, and block up the hole that the hose used to be connected to.
Heres a website I whipped together for ya, hopefully its reasonably clear:
clickity clickity click here!
My profile!
Dirtbag
Postby phat_levin » Sat Jul 29, 2006 5:08 am
very clear, just what i needed! thanks so much :lol:
i presume i need a catchcan with a breather, all the ones iv seen dont have breathers/filters, where can i get one from? im in chch......
phat_levin
Postby Dirtbag » Sat Jul 29, 2006 1:26 pm
No worries :D
Yea you will need a catch can with 3 holes, 2 inlets (usually on the side) then one outlet at the top for the filter, i know supercheap dont have them, i had a mate search their catalogues, but your usual places like repco etc should have them, or you could get one from trademe, or support toyspeed sponsors and get one from http://www.drivenperformance.co.nz (I think they have them)
edit:
http://www.drivenperformance.co.nz/scripts/prodList.asp?idCategory=36
why yes, yes they do ^^^^^^
My profile!
Dirtbag
Postby phat_levin » Sat Jul 29, 2006 2:56 pm
the cans on drivenperformance only have 2 holes? from what i can c :?
phat_levin
Postby Dirtbag » Sat Jul 29, 2006 3:08 pm
Oh yea, I would reccomend getting one of the cans off trademe, there are couple of 1 litre ones on there, for around the price of half the capacity of driven performance. $90 buy now, search for catch can on trademe. They have 3 holes, and can include a breather for an extra $15.
http://www.trademe.co.nz/a.asp?id=64096530 something like that, u cud post on one of his other auctions asking for one to be listed.
My profile!
Dirtbag
Postby RS13 » Sat Jul 29, 2006 6:47 pm
Eurgh, I'd recommend staying away from the ones with plastic fittings, and plastic "viewing" pipe, as they tend to leak. The first one I bought off trademe, arrived at my door with a broken plastic elbow, not what you want when its' going into a violently vibrating engine bay! I read back through the sellers feedback, a number of others had complained about them leaking, I would recommend just getting a custom one made up, to fit into your engine bay.
RS13
Postby phat_levin » Sat Jul 29, 2006 7:31 pm
dirtbag, what is the other hose that comes off the other side of the intake pipe that goes over to a little 'thing' on the fire wall and then goes back accross to the head? i have it all figured out now, will get one of those cans off trademe, if the 'little plastic' bits $&#$% out ill deal with it then lol, if i leaks guess idont have to empty it as often haha
phat_levin
Postby Dirtbag » Sun Jul 30, 2006 2:37 am
RS13 wrote:going into a violently vibrating engine bay!
Hmm, good point, wud fitting it to the chassis, or a point thats "inside" the engine mounts be better?
Anywhere good in chch that you could reccomend for it? What kinda prices would they be.
phat_levin, do you mean this pipe (one in yellow)
Frankly, no idea, maybe someone else could shed some light on it, I cant actually remember where it does flow to, as you kinda lose sight of it as it goes under the strut bar....
My profile!
Dirtbag
Postby phat_levin » Sun Jul 30, 2006 1:44 pm
no not that one, the one just to the right of that tho, heading off towards the right....
phat_levin
Postby Dirtbag » Sun Jul 30, 2006 11:07 pm
No idea eh, some sort of vaccuum thingy?
My profile!
Dirtbag
Postby sergei » Sun Jul 30, 2006 11:24 pm
Far top right is for A/C idle up.
Yellow is one of the 2 vacuum supply lines for brake booster (nut looking thing is one way valve).
