MIG vs. Arc/stick welding...
Postby sheepers » Fri Jul 28, 2006 10:23 pm
mother of crap!!! dont use flux wire!!!
splatter from arse to breakfast.
migs are pretty good but gasless wire is too much. i wont allow it!!!
p.s, i just did all this research as regards mig vs tig. there is little cost diffrence between comparable machines. mig is the more well used but there is no questinon that tig is the more versatile welder, and with a bit of practice youll get a better result no matter what you medium.
i guess this makes it my 4 cents.
sheepers.
:wink:
sheepers
Postby VR-4Squid » Sat Jul 29, 2006 2:04 am
sheepers wrote:mother of crap!!! dont use flux wire!!!
splatter from ar*e to breakfast.
I disagree. there is more splatter than when using ordinary wire with gas, but abit of fiddling with wire speed and heat settings will eliminate most of it. the rest can be cleaned up in 30 seconds with a wire brush anyway.
SquidInc Custom CARtoons
VR-4Squid
Postby fangsport » Sat Jul 29, 2006 10:19 am
seconded. because we don't have a high demand for welding at work, i only use gasless flux-core wire and don't have major splatter issues.
fangsport
Postby neo » Mon Jul 31, 2006 2:12 pm
It all depends on budget...
Pies, you can buy direct from the supplier to get a Cygweld, mine cost me $1400 odd for a commercial mig. I ran with c02 (soda stream bottles) for 6 months, before moving to Argosheild.
Migs a piece of piss to use (esp if you get an automatic darkening helmet). Tig is an art from. Arc is for making trailers and fixing boats, way too heavy for car stuff (I have one too, waste of time, the mig does it all if you get a good one)
Only downside is stainless steel... =(, and you need to re-engineer half of a mig for alloy
neo
Postby VR-4Squid » Tue Aug 01, 2006 12:04 am
get the wrong reel of wire off the garage shelf, and try using ordinary wire without gas however, and it's a different story, splatter from ar$e to breakfast, and beyond!! :oops:
VR-4Squid
Postby vvega » Wed Aug 02, 2006 3:09 pm
pies go to a welding shop and ask there for advice on welders
ive just read this threed and IMO the couple of accurate resposes are completely hidden buy the rest of bushit spewing forth
mig/mag, tig and arc are all good welders
you can with practice make arc welds as nice as mig
and for teh record
YOU CANNY MAKE MIG WELDS LOOK LIKE TIG WELDS
unless your a complete retard with a tig or you dont know how to tell
v
vvega
Postby Paulio » Thu Aug 03, 2006 12:10 am
Youre all confusing the boy haha
Paulio
Postby Pies » Thu Aug 03, 2006 6:45 pm
I WANT MY MUM!!!!!! :cry: :cry: :cry: :cry: :cry: :cry:
*hides in his corner*
Current Rides:
Pies
