fivebob wrote:It's probably not an O2 sensor, it's more likely to be the cat overheat sensor which you don't need.
Ae92typeX wrote:fivebob wrote:It's probably not an O2 sensor, it's more likely to be the cat overheat sensor which you don't need.
yep, just the cat sensor.
could always gutt the cat and bolt back in also.
